2007_Shelby_GT Posted October 27, 2014 Author Report Share Posted October 27, 2014 The O-rings are there to aid in keeping dirt/grime out of getting into the spherical ends. You should be able to get replacements at a local hardware store. Keeping the spherical ends clean will prolong their life expectancy. You should wipe the dirt off of them occasionally and spray them off with WD-40 or something equal to it. +1 on their purpose, but I'm curious about the WD-40? It's got some lubricating properties, but it's also kind of a solvent as well - wondering if something like a silicon-based lube might be better and less destructive to the o-rings? Not arguing, but wanting to know! Sam Link to comment Share on other sites More sharing options...
IASHELBYGT Posted October 27, 2014 Report Share Posted October 27, 2014 They are a bitch to get on when doing the install. Definetly need a second set of hands Link to comment Share on other sites More sharing options...
Kevin Patten Posted October 27, 2014 Report Share Posted October 27, 2014 +1 on their purpose, but I'm curious about the WD-40? It's got some lubricating properties, but it's also kind of a solvent as well - wondering if something like a silicon-based lube might be better and less destructive to the o-rings? Not arguing, but wanting to know! Sam Sam, All that I'm stating here is that spherical ends need to have maintenance ( dirt plays a major factor in their failure ) done to make them last and a good way to get long life out of them is to keep them clean and have a light lubricant on them. But you are right in the point that rubber is a petroleum based product and silicone does dissipate moisture - so a petroleum based spray is probably better on the o-rings than silicone based. JMO Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted October 27, 2014 Author Report Share Posted October 27, 2014 Sam, All that I'm stating here is that spherical ends need to have maintenance ( dirt plays a major factor in their failure ) done to make them last and a good way to get long life out of them is to keep them clean and have a light lubricant on them. But you are right in the point that rubber is a petroleum based product and silicone does dissipate moisture - so a petroleum based spray is probably better on the o-rings than silicone based. JMO You have no argument from me! I'm really curious now, so I sent an email to Jim Fay to see what he recommends! (Maybe just some good ole 3-N-1) Sam Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted October 27, 2014 Author Report Share Posted October 27, 2014 Straight from Jim Fay: "Periodic cleaning of the rod ends will be fine....IF you make sure to remove all the oily residue that will just attract dirt.We just wipe the components off with a clean rag while the oil is draining at your changes." Guess it doesn't matter WS-40 or something else, just wipe off the residue! Sam Link to comment Share on other sites More sharing options...
