Spectre500 Posted November 26, 2013 Report Share Posted November 26, 2013 I just changed out my 2010's rear OEM springs with Strange Dead Hooker Springs, the drop was about an inch. Swapped out the DS to a 1 pc Alum and went with BMR Adj LCA.. Set to the top hole on the BMR lower relocation bracket. What should the pinion angle be set to? I've been reading that -1.5 to -2 will be in spec. Also I've read to take a reading at the rear of the DS and then at the pinion flange of the rear differential. Is this correct? and which is the best hole to set the LCA arm on the relocation bracket for Street and Occasional strip use,. Link to comment Share on other sites More sharing options...
Kevin Patten Posted November 28, 2013 Report Share Posted November 28, 2013 Put the LCA in the hole of the relocate bracket which sets the LCA at the most parallel to the ground . Need to know what your flange angle is @ the trans output , driveshaft angle , and diff flange angle . Link to comment Share on other sites More sharing options...
Spectre500 Posted November 29, 2013 Author Report Share Posted November 29, 2013 OK will post up #'s when I take it in to the shop to do the upper this weekend. Link to comment Share on other sites More sharing options...
2112 Posted November 29, 2013 Report Share Posted November 29, 2013 I would love to see how you accurately measure the Pinion angle. Is there a special protractor available for this? . Link to comment Share on other sites More sharing options...
Robert M Posted November 30, 2013 Report Share Posted November 30, 2013 I would love to see how you accurately measure the Pinion angle. Is there a special protractor available for this? . Yes, it is available at your local Home Depot for $8 or so................ It has a magnetic mount on one side to stick it to the pinion flange and get a angle measurement.......... and the other side can be placed on the driveshaft to get its angle measurment......... Below is a link to the BMR 2011-up Adjustable UCA and at the lower portion of this link is a downloadable .pdf for the install, the angle adj. info. is at the bottom of this install .pdf link. http://www.bmrsuspension.com/index.cfm?page=products&productid=1020 An FYI...............the - (negative) pinion angle is down and the + (positive) pinion angle is up from the center line of the pinion. The BMR info. talks about - negative pinion angle. The Home Depot angle finder shown above does not indicate - or +, you just have to know by the angle shown if you are + or - and which way you need to adjust the UCA. R Link to comment Share on other sites More sharing options...
2112 Posted November 30, 2013 Report Share Posted November 30, 2013 Robert, thank you for all that! Link to comment Share on other sites More sharing options...
Robert M Posted December 1, 2013 Report Share Posted December 1, 2013 Robert, thank you for all that! You're welcome. R Link to comment Share on other sites More sharing options...
Spectre500 Posted December 10, 2013 Author Report Share Posted December 10, 2013 Got it ... Trans output shaft was @ 3 pointing downward and pinion flange is set to 1 pointing downward. Link to comment Share on other sites More sharing options...
Spectre500 Posted December 10, 2013 Author Report Share Posted December 10, 2013 Yes Thank you Robert. Link to comment Share on other sites More sharing options...
Robert M Posted December 11, 2013 Report Share Posted December 11, 2013 Yes Thank you Robert. You're welcome also. R Link to comment Share on other sites More sharing options...
