svttim Posted December 17, 2013 Report Share Posted December 17, 2013 You can get the studs in without removing the axle. You then have to pull the stud using a lug and spacer. You have to be careful to seat the stud but not over torque the stud. AB500 is correct, its not the best way but its always worked well for me Link to comment Share on other sites More sharing options...
2112 Posted December 19, 2013 Report Share Posted December 19, 2013 The front hubs are easy if you are already doing your own front brake jobs - just pop off the center cap and have a 35MM or 36MM socket and a breaker bar along with a torque wrench that goes up to 250 FT/LBS . The hubs come with new axle nuts ( the old ones are not to be reused ) . As far as the rears go that's a little more involved because of having to pull the axles ( yes some guys snake the studs in past the bracket and use a nut/washer set up to pull them in - but that is not the correct way to doing it - if it does not get fully seated then you may find yourself with loose lug nuts after running the car ) and getting them pressed into the axles. Do you have the part # on the Front Hubs? I am looking at the Ford Racing catalog now and am not finding them. Thanks . Link to comment Share on other sites More sharing options...
Kevin Patten Posted December 19, 2013 Report Share Posted December 19, 2013 Part # M-1104-A Link to comment Share on other sites More sharing options...
2112 Posted December 19, 2013 Report Share Posted December 19, 2013 Thank you. Heck, not much more than the studs themselves! https://www.fordracingparts.com/parts/part_details.asp?PartKeyField=10407 Love to find a Mini press that can push the rears in while the axle is assembled. . Link to comment Share on other sites More sharing options...
Kevin Patten Posted December 19, 2013 Report Share Posted December 19, 2013 Thank you. Heck, not much more than the studs themselves! https://www.fordracingparts.com/parts/part_details.asp?PartKeyField=10407 . and that is for a pair ! Link to comment Share on other sites More sharing options...
