MichaelGoodwin Posted November 16, 2013 Report Share Posted November 16, 2013 Good morning everyone. Well yesterday I installed my VMP pulley and idler. When I began to install the pulley the screw snapped inside the supercharger shaft. I contacted VMP and was told to drill it out which I tried to no success. The pulley is on most of the way and have less than 1/4" more to go on. What would be the most efficient or easiest way to put this on? If any of you are in the Jacksonville FL area and would like to come by and show me how to get this thing on then I'm buying the beers. I'm stomped and really would like to get this on without tearing apart the supercharger to install on a press. Any suggestions???? Link to comment Share on other sites More sharing options...
07SGT2899 Posted November 16, 2013 Report Share Posted November 16, 2013 honestly, and I know it's a pain, but being a toolmaker, i'd find a good machine shop to take the blower to and have the broken screw removed Link to comment Share on other sites More sharing options...
MichaelGoodwin Posted November 16, 2013 Author Report Share Posted November 16, 2013 Yeah i thought that would be the case. I'm trying one las technique before going that route. maybe i can get it on all the way by heating it up for a lil while in the oven. is so i'm good till and then i can coordinate to have it swapped on my next off day. i gotta get this repaired before the morning lol. Link to comment Share on other sites More sharing options...
frydguy79 Posted November 16, 2013 Report Share Posted November 16, 2013 i have had that happen, and got it worked out.. i am a long ways from you..... Link to comment Share on other sites More sharing options...
MichaelGoodwin Posted November 17, 2013 Author Report Share Posted November 17, 2013 Got it machined out and now issue number 2. My tune from VMP wont take. Keeps saying my stock tune is corrupted. I can't win for losing. lol. VMP actually responded to my email today so I will try some of the troubleshooting techniques they told me about once I'm off from work. I will also be calling SCT tomorrow for further info. Link to comment Share on other sites More sharing options...
awakeinAZ Posted November 17, 2013 Report Share Posted November 17, 2013 If you got am email tune, try to down load to your flasher one more time. I have gotten a corrupt one once. If you want to drive your car, put the stock airbox on and flash back to stock. Car should run fine. Link to comment Share on other sites More sharing options...
MichaelGoodwin Posted November 17, 2013 Author Report Share Posted November 17, 2013 Yeah i didnt have time to swap it back to stock so i drove to work slow as hell. No issues so far and hoping it doesn't ever give me one while I'm waiting to get this tune together. Link to comment Share on other sites More sharing options...
awakeinAZ Posted November 17, 2013 Report Share Posted November 17, 2013 It will work out! Link to comment Share on other sites More sharing options...
super hiss Posted November 20, 2013 Report Share Posted November 20, 2013 sct pissed me off when i installed my blower. the updates. returning to stock then new tune... Link to comment Share on other sites More sharing options...
MichaelGoodwin Posted November 22, 2013 Author Report Share Posted November 22, 2013 My issue is fixed. The machinist at RPM drilled out the broken bolt from the shaft then rethreaded it. Now what baffles me is that when he put the 2.59 pulley on, he didn't make it flush with the supercharger shaft. Is that normal? It sticks out a 1/8" off the from the beginning of the shaft. He told me that is normal due to if he made it flush the back of the pulley would make contact with the housing of the supercharger. Now is this wrong cause I recall that when the stock pulley was on it sat flush with the shaft. Can someone fill me in on this? Should I go ahead and push this pulley flush or leave it as is? Link to comment Share on other sites More sharing options...
aonebadbone Posted November 22, 2013 Report Share Posted November 22, 2013 If the belt looks straight then its ok If not the pulley will eat the belt fast Link to comment Share on other sites More sharing options...
54First Posted November 23, 2013 Report Share Posted November 23, 2013 He told me that is normal due to if he made it flush the back of the pulley would make contact with the housing of the supercharger. It should be flush or within 1/32" further back. Depends on the pulley and/or the blower. A 2.59 fits just fine with no contact with the blower housing. Unless the shaft is pushed back into the housing. That can happen. Did you bang or push on it when you said you were going to heat it up to get it on by morning? That could have pushed it back. If so, it needs to be pressed forward. Steve Link to comment Share on other sites More sharing options...
