jaydub Mach1 Posted November 14, 2013 Report Share Posted November 14, 2013 Hi Guys, I have one of the '07 SGT-California's that came with the 3 Gauge Pack that's mounted on top of the dash board. I noticed that the lights were out on all three gauges, driving home tonight. Does anybody know how Shelby wired these up? I assume that each gauge has its own light bulb. So, maybe the fuse has blown. All other instrument lights are functioning properly. I don't believe that the gauges are on the same circuit as the other instrument lights, since the gauge lights don't dim when the dimmer wheel is rotated. Has anybody replaced the bulbs or fuses before? Jer? Do you guys have the wiring diagram for this? Thanks in advance!!! Link to comment Share on other sites More sharing options...
Elgin Black Posted November 14, 2013 Report Share Posted November 14, 2013 Check your ground wire.Interesting your gauge pod lights don't dim with your instrument lights. When I installed my gauge pod the instructions had me wire them in with the dash lights. Link to comment Share on other sites More sharing options...
Don Johnston Posted November 14, 2013 Report Share Posted November 14, 2013 When my 3 gauge lights failed to work, I tried the simplest test. I turned the interior light intensity adjustment dial on the dash and they came on! They are either on or off, no intensity variation. I had to set the dial to almost full intensity, just before the dial clicked to off!. I assume this is necessary as they are wired in with the standard dash lights and need to draw full current. I had to do the check at night in order to see the gauge lights as they are not very strong. Link to comment Share on other sites More sharing options...
Rattlesnake Posted November 14, 2013 Report Share Posted November 14, 2013 As SLYGRAY1 suggested the instructions call for the lights to be wired into the light switch and that means they get the use of the dinner switch. I also think you should check the ground to make sure it is still intact... Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted November 14, 2013 Author Report Share Posted November 14, 2013 Thanks for the suggestion, guys! ! I will look into those! Link to comment Share on other sites More sharing options...
Jer Posted November 14, 2013 Report Share Posted November 14, 2013 It's a small wiretap installed behind the headlight switch panel. It can be pried out and checked for a physical disconnection... Call me if you don't find anything obvious. Jer Link to comment Share on other sites More sharing options...
Elgin Black Posted November 14, 2013 Report Share Posted November 14, 2013 The wiretap Jer is refering to is the white power wire from the gauge pod connecting to the black wire with the white tracer stripe at the headlight switch. Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted November 14, 2013 Author Report Share Posted November 14, 2013 I'll check it out. Thanks, again, Guys!!!!!!! Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted November 15, 2013 Report Share Posted November 15, 2013 Jer - isn't there a white wire with yellow tracer that the gauge pack also taps into? I remember digging around under the dash through a mass of wires trying to find THAT one! Sam Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted November 15, 2013 Author Report Share Posted November 15, 2013 It's a small wiretap installed behind the headlight switch panel. It can be pried out and checked for a physical disconnection... Call me if you don't find anything obvious. Jer I finally got a chance to pop out the headlight switch assembly. The wire to the gauge pod had come unplugged from the splicer piece. The colors were was just as slygray1 stated. The wire that went off to the gauge pod was white and the splice assembly was crimped onto the black with a yellow tracer wire. Thanks, again, all and Team Shelby for having this forum to provide the mechanism to resolve issues!!! Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted November 16, 2013 Report Share Posted November 16, 2013 I finally got a chance to pop out the headlight switch assembly. The wire to the gauge pod had come unplugged from the splicer piece. The colors were was just as slygray1 stated. The wire that went off to the gauge pod was white and the splice assembly was crimped onto the black with a yellow tracer wire. Thanks, again, all and Team Shelby for having this forum to provide the mechanism to resolve issues!!! Very cool! Link to comment Share on other sites More sharing options...
