Tom M. Posted September 11, 2013 Report Share Posted September 11, 2013 Ever since I got my 2012 GT500 at odd intervals my TPMS error message keeps coming on... then it goes away. (Not the low inflation warning but the TPMS system error.) A half hour later it comes back on, I reset it, and after a few minutes it goes away again. It doesn't seem to be connected to going over big bumps or anything like that. The dealer looked at it but said he could only fix it if the light was on when he got it. Fine, but even if I drive around until it comes on and then shoot right to the dealer by the time they look at it it would be gone. On my big drive through West Virginia 2 weeks ago it kept coming on, and once or twice the Stabilitrak error light came on too. Any ideas? It's the only fault so far. Thanks, Tom M. Quote Link to comment Share on other sites More sharing options...
ViperNC Posted September 11, 2013 Report Share Posted September 11, 2013 You likely have a bad sensor in one of your wheels. I'd take it back to Ford and make them replace under warranty. Quote Link to comment Share on other sites More sharing options...
ingram4868 Posted September 12, 2013 Report Share Posted September 12, 2013 One of our members worked with the dealer and they installed a logging device. I would ask if they have one or can get one on loan. Quote Link to comment Share on other sites More sharing options...
Tom M. Posted September 12, 2013 Author Report Share Posted September 12, 2013 ViperNC, you're right I probably do have a bad sensor but the question is which one? My Acura tells you which one is bad but Fords don't as far as I know. And what if it's the transmitter in the car rather than the wheels? David thanks for mentioning that I'll ask the dealer. Tom M. Quote Link to comment Share on other sites More sharing options...
ViperNC Posted September 12, 2013 Report Share Posted September 12, 2013 The dealership should have a scanning device that would be able to tell which one is bad. It's the same device they use to activate the sensors with the TPMS system. Quote Link to comment Share on other sites More sharing options...
Doug_GT350 Posted September 12, 2013 Report Share Posted September 12, 2013 Where in the "Northeast" are you located? I have a resetting tool as does any dealer and/or tire shop. I would try to reset the sensors even if the light is not on just to see if it helps. You may wind up finding the bad one while trying to reset them. Quote Link to comment Share on other sites More sharing options...
Tom M. Posted September 12, 2013 Author Report Share Posted September 12, 2013 (edited) I live in Worcester PA outside Philly... I hope to be at Rocktoberfest. I did try resetting the sensors, it didn't help. Tom M. Edited September 12, 2013 by Tom M. Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted September 12, 2013 Report Share Posted September 12, 2013 ViperNC, you're right I probably do have a bad sensor but the question is which one? My Acura tells you which one is bad but Fords don't as far as I know. And what if it's the transmitter in the car rather than the wheels? Maybe a silly question but....Did you check the air pressure in all of your tires??? Phill Quote Link to comment Share on other sites More sharing options...
Doug_GT350 Posted September 12, 2013 Report Share Posted September 12, 2013 I live in Worcester PA outside Philly... I hope to be at Rocktoberfest. I did try resetting the sensors, it didn't help. Tom M. okay then I guess I can't help.... but at least we think alike!!! Have fun at Rocktoberfest, I'm going to miss it this year due to my daughters wedding. Remember, don't fill up at breakfast because lunch will be served right after and both have always been a great meal! Quote Link to comment Share on other sites More sharing options...
Tom M. Posted September 12, 2013 Author Report Share Posted September 12, 2013 Phil, not a silly question but yes I did check them with my calibrated TPG, 35.5 PSI all the way around. Doug, I probably won't pre register so I don't get the food. Tom M. Quote Link to comment Share on other sites More sharing options...
ingram4868 Posted September 13, 2013 Report Share Posted September 13, 2013 I just remembered that I took my car to Discount Tire once and they did have a scanner tool to identify the bad sensor. Quote Link to comment Share on other sites More sharing options...
Doug_GT350 Posted September 13, 2013 Report Share Posted September 13, 2013 Phil, not a silly question but yes I did check them with my calibrated TPG, 35.5 PSI all the way around. Doug, I probably won't pre register so I don't get the food. Tom M. Johns easy to get along with, he'll let you pay the day of the show..... just tell him Doug said it was okay! Quote Link to comment Share on other sites More sharing options...
David Hawkins 6722 Posted September 13, 2013 Report Share Posted September 13, 2013 The 205-2009 Mustangs had Blue Box type Sensors that were held on with Double Sided Tape and Metal Bands. If a Sensors are the same type and it is not bad, it could be that it may have broke lose from the Wheel. I have seen it happen before. Quote Link to comment Share on other sites More sharing options...
