frazierfreud Posted September 7, 2013 Report Share Posted September 7, 2013 Wider wheels with wider and stickier tires...hmm. Sounds like nice mod. I see jongbloed makes a 700 series wheel designed for the boss 302. 18"x10.5" on all 4 corners...about $1700. Weigh about 24 pounds. Anyone have other ideas on similar sized wheels at a similar price? Some 315 width nt01 on all 4 corners sounds pretty nice! Quote Link to comment Share on other sites More sharing options...
OsirisGT500 Posted September 8, 2013 Report Share Posted September 8, 2013 I don't have experience with these wheels. I went the Enkei route. But for sure lighter wheels and good race / track tires were the biggest lap time improvement I have seen for my car. The problem is do you want to drive to the track on them or change them there. I decided to get a truck and trailer for this reason. From there the car has been more and more track only. It seems you have the bug for track day driving and I say go for it. Quote Link to comment Share on other sites More sharing options...
TurboGT Posted September 10, 2013 Report Share Posted September 10, 2013 Jongbloeds are a very nice track wheel but being very light they are not durable enough to drive back & forth to the track IMHO - at least not very far, and certainly not on the roads where i live. If you can afford to have a dedicated track set to change at the track they would be tough to beat. I've been looking hard at the Enkei PF01 as they are fairly light, very reasonably priced and capable of very light street driving. Like you, my ideal track tire would be NT01's in 315 on all four corners. FWIW, there was a great deal in the classifieds recently on a pair of 3 piece Forgeline in 18"X10. These are top of the line wheels and are serviceable if you damage a rim. Problem is, at $1500 apiece to buy two more they are too rich for my blood. I can buy 5 brand new Enkeis with tires for the cost of those rims alone. Quote Link to comment Share on other sites More sharing options...
frazierfreud Posted September 10, 2013 Author Report Share Posted September 10, 2013 there is some question if 18"x10.5" with 315 nitto nt01 would fit on the front of the car. possibly they may rub? or may rub at full turn only? Quote Link to comment Share on other sites More sharing options...
Kevin Patten Posted September 10, 2013 Report Share Posted September 10, 2013 You have to have the proper offset strut body and wheel offset to run and the manufacturer of tire . As far as turning goes you have to have the right steering stops to match up with the tire/wheel combo when ever you change from the stock sizes/offsets. FRPP and Roush both sell the different size steering stops that go on the rack . Quote Link to comment Share on other sites More sharing options...
Kevin Patten Posted September 11, 2013 Report Share Posted September 11, 2013 You might want to check out CCW for wheels also . A lot of track folks have been running them for years. Quote Link to comment Share on other sites More sharing options...
svttim Posted September 11, 2013 Report Share Posted September 11, 2013 http://www.vorshlag.com/index.php?cPath=141_142_268 Quote Link to comment Share on other sites More sharing options...
39Mustang Posted October 9, 2013 Report Share Posted October 9, 2013 lol, I just saw this and I kind of asked the same question Quote Link to comment Share on other sites More sharing options...
TurboGT Posted October 10, 2013 Report Share Posted October 10, 2013 315's will rub unless you have offset front struts. If you have Griggs front coilovers you may be OK but I'd ask Bruce Griggs first to be sure. Quote Link to comment Share on other sites More sharing options...
cluscher Posted October 15, 2013 Report Share Posted October 15, 2013 I spoke to Bruce Griggs and he offers an 18x10.5 wheel in +45mm offset.....very reasonably priced. He said they run 315s squared all the time, but I believe that is only with the Griggs coilovers. I'd give him a call. Quote Link to comment Share on other sites More sharing options...
Kevin Patten Posted October 15, 2013 Report Share Posted October 15, 2013 I spoke to Bruce Griggs and he offers an 18x10.5 wheel in +45mm offset.....very reasonably priced. He said they run 315s squared all the time, but I believe that is only with the Griggs coilovers. I'd give him a call. I believe that is only with his SLA front suspension set up . Quote Link to comment Share on other sites More sharing options...
TurboGT Posted October 15, 2013 Report Share Posted October 15, 2013 FWIW - CorteX says 315's will fit with just the offset front coilover setup using a 45-47mm offset wheel without changing front control arm setup. I am hopeful this is the case as I would like to try a square 315 setup for the track eventually. Quote Link to comment Share on other sites More sharing options...
Kevin Patten Posted October 16, 2013 Report Share Posted October 16, 2013 It will on the Cortex because of the additional offset that they have on their coilover strut . Quote Link to comment Share on other sites More sharing options...
cluscher Posted October 16, 2013 Report Share Posted October 16, 2013 I believe that is only with his SLA front suspension set up . That's what I thought too. I specifically asked about a non-SLA front and he said "we do it all the time." He said you might have to get aggressive with camber and/or run a thin spacer. Thinking 305/35 on 10.5 inch wheel squared is a viable option even without the SLA. Heck, run those 305s on a Forgestar 18x10 and get the offset you want. Quote Link to comment Share on other sites More sharing options...
Kevin Patten Posted October 16, 2013 Report Share Posted October 16, 2013 That's what I thought too. I specifically asked about a non-SLA front and he said "we do it all the time." He said you might have to get aggressive with camber and/or run a thin spacer. Did he happen to mention what he feels is a "thin" spacer ? 3mm , 5mm , .250" ? Quote Link to comment Share on other sites More sharing options...
svttim Posted October 16, 2013 Report Share Posted October 16, 2013 Just curious why you are looking for this large a tire? Quote Link to comment Share on other sites More sharing options...
Kevin Patten Posted October 16, 2013 Report Share Posted October 16, 2013 Just curious why you are looking for this large a tire? Because they think that one should put the biggest tire on the narrowest wheel ? Quote Link to comment Share on other sites More sharing options...
mark.barton Posted October 16, 2013 Report Share Posted October 16, 2013 Just curious why you are looking for this large a tire? Wider tires = faster time ????? Mark Quote Link to comment Share on other sites More sharing options...
gpsn Posted October 16, 2013 Report Share Posted October 16, 2013 I'm not looking for large wheels for the drag strip--I am looking for suggestions. Obviously my (rear) 20's on 2014 Shelby GT have to be replaced. a few suggested 15's would me best w/ a slick. I'm new to the sport--so looking for best for my car Quote Link to comment Share on other sites More sharing options...
cluscher Posted October 17, 2013 Report Share Posted October 17, 2013 Did he happen to mention what he feels is a "thin" spacer ? 3mm , 5mm , .250" ? He wasn't specific but did say you "may" need a thin spacer. I took that to mean 3 to 5mm, but that was just my assumption. Quote Link to comment Share on other sites More sharing options...
Kevin Patten Posted October 17, 2013 Report Share Posted October 17, 2013 General rule of thumb 275s or 285s on a 9-1/2 to 10 rim , 295s or 305s on a 10-1/2 rim - to keep the sidewalls of the tires parallel to one another. Others go off of the " tire sectional width .5" to 1" wider than the measured rim width ( inner bead to bead width )" . Tire Rack has some tech articles to explain . In order to maximize the tire contact patch you don't want too wide of a tire on a rim because the sidewalls point outward from the rim and roll up the side portions of the tread area causing less contact and an applied force right where the edge of the belts are laid under the tread thus increasing the possibility of getting tread separation from the belts . Of course even in similar size tires sectional width can vary from manufacturer to manufacturer. JMO Quote Link to comment Share on other sites More sharing options...
gpsn Posted October 17, 2013 Report Share Posted October 17, 2013 found thes 18's that will fit my 2014 Black S197 Mustang Saleen Style Wheel 18x10 (05-14 All), now going ti research a decent slick Quote Link to comment Share on other sites More sharing options...
svttim Posted October 18, 2013 Report Share Posted October 18, 2013 Wider tires = faster time ????? Mark if it were that easy Quote Link to comment Share on other sites More sharing options...
mark.barton Posted October 18, 2013 Report Share Posted October 18, 2013 if it were that easy Agreed. Mark Quote Link to comment Share on other sites More sharing options...
gpsn Posted October 18, 2013 Report Share Posted October 18, 2013 just trying to launch--cheater slick that came stock on 2014 are useless for the drag strip Quote Link to comment Share on other sites More sharing options...
gpsn Posted October 18, 2013 Report Share Posted October 18, 2013 does anyone make an 18 inch slick? (not drag radial) Quote Link to comment Share on other sites More sharing options...
39Mustang Posted October 23, 2013 Report Share Posted October 23, 2013 are 18 x 9.5 wheels better for racing than 20 x 9? And are more street legal tires available more in 18 than 20? Quote Link to comment Share on other sites More sharing options...
svttim Posted October 23, 2013 Report Share Posted October 23, 2013 are 18 x 9.5 wheels better for racing than 20 x 9? And are more street legal tires available more in 18 than 20? Yes, 18 would be lighter and there are way more (read less expensive) tires to choose from Quote Link to comment Share on other sites More sharing options...
39Mustang Posted October 24, 2013 Report Share Posted October 24, 2013 Yes, 18 would be lighter and there are way more (read less expensive) tires to choose from off hand do you know the biggest tire I could fit if use a 18x9.5 wheel? I'd be using it on my 2008 Shelby GT/SC w/ Shelby Extreme brakes front and rear Quote Link to comment Share on other sites More sharing options...
Frank S Posted October 25, 2013 Report Share Posted October 25, 2013 I did the GT500 18x9.5 wheels with what were supplied on the rear of the '07-'08-'09 GT500s, 285-40. You can make almost anything "fit", but bigger than that will be over the tire manufacturers' recommendations for safe all-around use. Both cars have the GT500 wheels; the front one 285s, the rear, 255s Quote Link to comment Share on other sites More sharing options...
