Aussie67 Posted August 18, 2013 Report Share Posted August 18, 2013 I have just fitted a new set of rims tyres and TPMS sensors to my 2007 GT500. I have the sensor training tool but I can't get the car to enter the tuning mode. I have found two procedures but both were done with a 2010 car but I believe it's the same for mine. Both procedures were basically the same: Turn ignition from off to on three times Press and release the brake pedal Turn ignition off and then to on three more times Car should beep and enter training mode The second procedure is exactly the same but includes depressing the brake pedal before you start. I have tried both ways many times but I can't get the car to beep and enter training mode? Can anyone help me out with this? Is the procedure the same for my car as later models? Am I missing something? This is a big problem for me as not too many people in Perth Australia know too much about Mustangs. Any suggestions greatly appreciated. Quote Link to comment Share on other sites More sharing options...
grsybtch Posted August 18, 2013 Report Share Posted August 18, 2013 This is the instructions I followed from American Muscle and it worked for me A couple of important pointers before we get started with this process, the TPMS syncing tool works on a specific radio signal, so you’ll want to make sure you don’t have any cell phones, walkie talkies, or radios around that could possibly cause any interference. Second, you’ll want to make sure you do this process about 10-20 feet away from other vehicles, again just to avoid any problems. To begin the syncing process, insert the key into the ignition and turn the key from the off to the on position 3 times, the third time leaving the key in the on position, without actually starting the car. With the key in the on position, press the brake pedal to the floor and then release it. At this point turn the key from the off to the on position 3 more times, once again leaving it in the on position the third and final time. At this point you should hear the horn honk to indicate that the TPMS sensors are ready to be synced to your ride, using the TPMS syncing tool. With the key still in the on position, head to the left front tire. You’ll need to hold the syncing tool to the valve stem making sure the arrow on the tool is aligned with the valve itself, hold the green button down and wait for the horn to honk, this means the tire has been synced to your ride properly. Repeat that step for the right front, the right rear, and finally the left rear. If you forget the order, just look at the display in the speedometer, it will tell you what tire to sync next. If you’re having problems with the sensors not being detected and the horn doesn’t sound in the syncing process, then deflate all 4 tires and let the car sit for 5 minutes, after that reinflate the tires to the manufacturers recommended PSI, then restart the syncing process. Since the wheels and TPMS sensors are programmed specifically for each location, you will need to resync your TPMS sensors every time you rotate your tires, otherwise you’ll receive inaccurate readings Quote Link to comment Share on other sites More sharing options...
Aussie67 Posted August 18, 2013 Author Report Share Posted August 18, 2013 Yes thanks for that, I found same, just can't get my car to accept. Thanks for posting though. Quote Link to comment Share on other sites More sharing options...
VNMSNK Posted August 18, 2013 Report Share Posted August 18, 2013 I used these from LMR on my 07, both of the 11's I had and my 12. They worked for all of my cars: http://cdn.lrsstatic.com/downloads/instructions/tpms%20instructions.pdf Hope it helps. Quote Link to comment Share on other sites More sharing options...
Doug_GT350 Posted August 19, 2013 Report Share Posted August 19, 2013 I found that by turning the key slowly (1-2 seconds between) worked for me, and I definitely pressed the pedal to start. I do however have a 2007..... Good luck. Quote Link to comment Share on other sites More sharing options...
6-Speed Posted August 19, 2013 Report Share Posted August 19, 2013 Which TPMS sensors are installed, aftermarket brand or the OEM band sensors? Quote Link to comment Share on other sites More sharing options...
6-Speed Posted August 19, 2013 Report Share Posted August 19, 2013 Here is the procedure I used, which is from the Mustang shop manual: Turn the ignition switch to the OFF position, then press and release the brake pedal. Cycle the ignition switch from the OFF position to the RUN position 3 times, ending in the RUN position. Press and release the brake pedal. Turn the ignition switch to the OFF position. Turn the ignition switch from the OFF position to the RUN position 3 times, ending in the RUN position. The horn will sound once and the TPMS indicator will flash if the training mode has been entered successfully. It's essentially the same as the procedure you followed with the addition of the first step of pressing the brake pedal while the ignition switch is off. Quote Link to comment Share on other sites More sharing options...
Aussie67 Posted August 19, 2013 Author Report Share Posted August 19, 2013 Thanks everyone for the input. This really had me beat as it seems like a really simple procedure. And it seems as though it is, however, apparently to meet Australian standards they have to modify the brake circuit wiring which obviously affects this procedure. So problem solved. Thanks again to everyone for the help. Quote Link to comment Share on other sites More sharing options...
Doug_GT350 Posted August 19, 2013 Report Share Posted August 19, 2013 Glad to hear ya got it fixed! Quote Link to comment Share on other sites More sharing options...
grsybtch Posted August 19, 2013 Report Share Posted August 19, 2013 Thanks everyone for the input. This really had me beat as it seems like a really simple procedure. And it seems as though it is, however, apparently to meet Australian standards they have to modify the brake circuit wiring which obviously affects this procedure. So problem solved. Thanks again to everyone for the help. Another case of Government "simplifying" life! Glad it's not only here Quote Link to comment Share on other sites More sharing options...
XY GTHO Phase III Posted August 21, 2013 Report Share Posted August 21, 2013 G'day Aussie 67, where abouts in Perth do you live. I'm originally from Nollamara. Also I've been looking for a 1970, 1971 XT GT but they seem to be as rare as rocking horse shit, are they that rare now a days, Thanks Rob Quote Link to comment Share on other sites More sharing options...
