Mustang horn button replacement
You need to find a factory Ford airbag delete they used in the Cobra Jet cars.
I bought one for my CS6 for around $80.00 from Blue Oval Industries a few years ago.
It took some time to dig out the clips etc. as they are encased in rubber as I wanted it perfect.
Then I just pried out the old one which was easy, put epoxy in the clip holes and under the button,
cut 50% of the retaining clips off the snake button and pressed it into place.
It worked perfectly.
Saleen used to make a cover that you could then put a sticker on.
I had one made but it required some cutting where the old emblem sat. I then used panel adhesive to bond it to the cover only on one half so that hopefully it won't cause problems if the airbag ever goes off.
