bmezz Posted June 19, 2013 Report Share Posted June 19, 2013 2007 Mustang Shelby GT..... Need help ........Very low on fuel so I was going to fill up,I started the car the engine ran I let the emergency brake off the engine quits. Did this 4 times, I then left the brake on one click engine stayed running,I drove to fill up, when I tried to leave Same thing happens. I put the emergency brake on one click and managed to make it to the Ford dealership engine light on since the beginning. Mechanic read the codes all The injectors showed faults. Now the Engine starts then stops right away. He could not figure out the problem left the car with them because it was closeing time. They said they would call me tomorrow. I know sounds weird. Does anyone have any idea what is going on? Or has this happened to anyone else there? Link to comment Share on other sites More sharing options...
07SGT Posted June 19, 2013 Report Share Posted June 19, 2013 CPU? Did you leave the engine running while fueling? How many miles- fuel filter? Or possibly an electrical short with the emergency brake pedal/switch/light and the CPU? Link to comment Share on other sites More sharing options...
bmezz Posted June 19, 2013 Author Report Share Posted June 19, 2013 1..no to running while fuel. Only 5500miles. Short is what I think but couldn't find it maybe mechanic will be able to Thanks hopefully will be fixed tomorrow. Link to comment Share on other sites More sharing options...
bmezz Posted June 19, 2013 Author Report Share Posted June 19, 2013 Thanks 07SGT... Check the ground wires to them two were loose tighten them up everything works fine. The ground wire for the CPU was the problem. Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted June 19, 2013 Report Share Posted June 19, 2013 Glad it was something simple! Sam Link to comment Share on other sites More sharing options...
07SGT Posted June 21, 2013 Report Share Posted June 21, 2013 Thank goodness. That was probably the cheapest serious repair yet!!!!! Link to comment Share on other sites More sharing options...
