venem07 Posted June 7, 2013 Report Share Posted June 7, 2013 i have a 2007 shelby super snake and would like some help with traction ideas. all i do is spin. i currently have pirelli tires 275 35 zr20. would a drag raidel help? all sugestions greatly appreciated. thanks Link to comment Share on other sites More sharing options...
IA Shelby Posted June 7, 2013 Report Share Posted June 7, 2013 Ditch the existing tires. Have Eric Vaughn widen the rear wheels to 11.5 and stick Toyo R888 315's outback. Add in LCA relocation brackets if you don't already have them. Done. Link to comment Share on other sites More sharing options...
2007tungstenGT500 Posted June 7, 2013 Report Share Posted June 7, 2013 yep i agree. i had mine widened to 11" and threw on R888 315 and also have control arm relo brackets and now i kinda miss some of the spin. Link to comment Share on other sites More sharing options...
venem07 Posted June 7, 2013 Author Report Share Posted June 7, 2013 thanks not sure if i have those brackets does it matter that shelby lowerd the car 1 inch? thanks Link to comment Share on other sites More sharing options...
2007tungstenGT500 Posted June 8, 2013 Report Share Posted June 8, 2013 technically, the brackets aren't needed. i drove my car lowered without them for a little while. also, i don't believe shelby puts them on any of their special edition GT500s. however, they are recommended to correct the geometry of the control arms on lowered applications. they are cheap enough so i added them and i have zero wheel hop. Link to comment Share on other sites More sharing options...
Secondo Posted June 8, 2013 Report Share Posted June 8, 2013 If you want traction, the brackets are needed. Especially on a lowered car. Link to comment Share on other sites More sharing options...
venem07 Posted June 9, 2013 Author Report Share Posted June 9, 2013 thanks for the info. if i have my rims widend is there need to have an offset? I heard eric vauhn does a good job? Will this effectthe finish on the rims? ANY HELP WITH THIS IS AWSOME THANKS GUYS Link to comment Share on other sites More sharing options...
ingram4868 Posted June 10, 2013 Report Share Posted June 10, 2013 No traction? This must have been the second posting on all forums. Link to comment Share on other sites More sharing options...
venem07 Posted June 10, 2013 Author Report Share Posted June 10, 2013 sorry if this a common topic. I have only been a member for a week. Just looking for help Link to comment Share on other sites More sharing options...
2007tungstenGT500 Posted June 10, 2013 Report Share Posted June 10, 2013 i had mine done by weldcraft. you can see the weld seam inside the rim, but it was grinded down to a smooth surface. over time, it's going to turn black from dirt and road grime anyway. in my case, there was no offset change. they simply added a couple of inches of material to the inner rim. Link to comment Share on other sites More sharing options...
venem07 Posted June 11, 2013 Author Report Share Posted June 11, 2013 Anyone know what the widest tire i can put on a 9 inch rim, also the best tire for traction. Drag radial? Thanks Link to comment Share on other sites More sharing options...
