SGT0767 Posted April 21, 2013 Report Share Posted April 21, 2013 I wanted to see if anyone could tell me what the normal KR shifter thread size and count is. My wife purchased a new KR shifter ball for me for Christmas. Unfortunately, the adapters were not shipped with it but Tim was able to get me out a set of adapters. When they arrived, I attempted to install the adapter but it would not screw onto the shifter. The size appears to be correct but the thread count is off. A quick call to Tim and he sent a second adapter but I have the same issue. I know that the standard KR ball is a 3/8-16 as I tested this at the local hardware store. I'ld like to verify that the 3/8-16 is standard or if I have an issue with my shifter that will require a special adapter to install the new shift ball. Thanks Mike Link to comment Share on other sites More sharing options...
msb64 Posted April 21, 2013 Report Share Posted April 21, 2013 Hey Mike If the size looks close but the thread count is off, it may be a 3/8 NF 24 thread instead of the 3/8 NC thread. If it is a metric thread, it may be something like 9 x 1.25, 10 x 1.0 or 10 x 1.5. For a few bucks at your local hardware store, you should be able to pick up a few sample nuts that will let you determine exactly what you have on there. Link to comment Share on other sites More sharing options...
SGT0767 Posted April 21, 2013 Author Report Share Posted April 21, 2013 I had tested the old ball so I was able to confirm that it used 3/8-16. I took the adapters to the local hardware store and sure enough, you were correct. The inside size/thread on the adapter is 10 x 1.25. Funny thing is that the nut that came with the adapter is also 3/8-16. I will give Tim a call tomorrow and see if we can get things ironed out. Thanks for the help. Mike Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted April 21, 2013 Report Share Posted April 21, 2013 The inside size/thread on the adapter is 10 x 1.25. That's for a 2010 or newer car. IIRC, the '09+ earlier had 12mm threads and the FRPP (which I thought the KR's had installed) was a SAE thread. Phill Link to comment Share on other sites More sharing options...
SGT0767 Posted April 21, 2013 Author Report Share Posted April 21, 2013 Hi Phil, Yes, the KR has a 3/8-16 thread. Since the adapter is definitely mm, it looks like the wrong adapter got packaged. Interestingly, the stop nut is the correct 3/8-16 size. Mike Link to comment Share on other sites More sharing options...
