Elgin Black Posted April 15, 2013 Report Share Posted April 15, 2013 Does anyone know if the running horse grill emblem is the same as the fender emblem on the 1965-1967 6 cylinder mustangs? Link to comment Share on other sites More sharing options...
19again Posted April 15, 2013 Report Share Posted April 15, 2013 I don't know if it's the same as a 66 6cly. But when I changed mine I bought it thru my local Mustang shop, Mustang of Chicago. It was exactly like the worn one that was original to our GT-H. Hope this helps. Or check out CJ Pony or NPD they will have what you are looking for. Link to comment Share on other sites More sharing options...
JeffJ Posted April 15, 2013 Report Share Posted April 15, 2013 I'm pretty sure that SPP has the emblem, but also, the old school part number is still the same. C5ZZ-16229-B Yes, here's the link to the Shelby Store part. Easy to find on the web site, just look under exterior parts. http://www.shelbystore.com/product-p/8s3z-8213-b.htm Link to comment Share on other sites More sharing options...
MyBlueHeaven Posted April 16, 2013 Report Share Posted April 16, 2013 Does anyone know if the running horse grill emblem is the same as the fender emblem on the 1965-1967 6 cylinder mustangs? yes it's the same, I bought one on ebay that was for a 66 in the original box and everything. I thought it would be nice to have a little bit of the old school on the car. they are identical. Originals say FoMoCo on the back and newer ones say scott drake I believe. Link to comment Share on other sites More sharing options...
ShelbyDW Posted April 17, 2013 Report Share Posted April 17, 2013 Found this one, relatively cheap. http://www.ebay.com/itm/MUSTANG-PARTS196566-RUNNING-HORSE-FENDER-EMBLEM-LH-E20-/271115626483 Link to comment Share on other sites More sharing options...
Elgin Black Posted April 18, 2013 Author Report Share Posted April 18, 2013 Thanks guys. I ended up buying one from SPP. And bought a spare on Ebay. They are identical to the ones being replaced on a 1967 sitting next to mine in the paint shop. The horse on my grill had faded and wanted to replace it while the grill is off. Link to comment Share on other sites More sharing options...
westxsgt Posted April 23, 2013 Report Share Posted April 23, 2013 it is the same-scott drake Link to comment Share on other sites More sharing options...
harristotle Posted April 23, 2013 Report Share Posted April 23, 2013 Found this one, relatively cheap. http://www.ebay.com/...0-/271115626483 Geez! Good price, especially if it's the same part. I'll have to order one. How on earth do you swap those things? I was checking it out yesterday, do I have to pull the plastic bit off the front of the engine bay? Link to comment Share on other sites More sharing options...
Wayne Grey Posted April 23, 2013 Report Share Posted April 23, 2013 I got a new in package Scott Drake on Ebay from CJ Pony Parts for $8.99 delivered and they have more available - spend more if you want to. Link to comment Share on other sites More sharing options...
JT93 Posted April 23, 2013 Report Share Posted April 23, 2013 Geez! Good price, especially if it's the same part. I'll have to order one. How on earth do you swap those things? I was checking it out yesterday, do I have to pull the plastic bit off the front of the engine bay? I pull the radiator support plastic cover off and loosen the four bolts that hold the actual grill in place. I'm too lazy to deal with pulling the housing in and out. Link to comment Share on other sites More sharing options...
harristotle Posted April 23, 2013 Report Share Posted April 23, 2013 I pull the radiator support plastic cover off and loosen the four bolts that hold the actual grill in place. I'm too lazy to deal with pulling the housing in and out. Perfect. For the plastic cover, are the plastic pins holding it just push pins like I'd find on interior trim? Link to comment Share on other sites More sharing options...
JeffJ Posted April 23, 2013 Report Share Posted April 23, 2013 Perfect. For the plastic cover, are the plastic pins holding it just push pins like I'd find on interior trim? Similar, but you do not force out the entire pin. Pull the center of the pin up, then the entire pin will slide right out. Most interior pins are not really reusable as they just push in. These pins are reusable if you do not break them. If so, easily replaceable. If using a small screw driver, do not pry up against the edge of the cover, you will most likely scratch it. Gently pry up against your finger or put a towel or somthing like that to pry up on. Should take very little effort to pop up the center, that unlocks the clip and you should be able to pull it right out with little effort. I hope that makes sense. Link to comment Share on other sites More sharing options...
harristotle Posted April 23, 2013 Report Share Posted April 23, 2013 Similar, but you do not force out the entire pin. Pull the center of the pin up, then the entire pin will slide right out. Most interior pins are not really reusable as they just push in. These pins are reusable if you do not break them. If so, easily replaceable. If using a small screw driver, do not pry up against the edge of the cover, you will most likely scratch it. Gently pry up against your finger or put a towel or somthing like that to pry up on. Should take very little effort to pop up the center, that unlocks the clip and you should be able to pull it right out with little effort. I hope that makes sense. It does, thank you! Link to comment Share on other sites More sharing options...
Kevin Patten Posted May 4, 2013 Report Share Posted May 4, 2013 I think that I'll go with the FRPP # M-16098-CJG instead of the running horse to let people know it's a snake ! :burnout: Link to comment Share on other sites More sharing options...
