GrabberO Posted May 3, 2007 Report Share Posted May 3, 2007 Couple of questions this morning…… Anyone experience a Tire Pressure Faulty Sensor warning? …..what did you do? What is your recommendation for psi on stock tires? Thanks Link to comment Share on other sites More sharing options...
Grabber Posted May 3, 2007 Report Share Posted May 3, 2007 Couple of questions this morning…… Anyone experience a Tire Pressure Faulty Sensor warning? …..what did you do? What is your recommendation for psi on stock tires? Thanks Take a look on your Door piller for the stock tire pressure reccomendation and follow that. It is 32 or 33 if I remember correctly...but check it out. Fill up the tires to that. Then take the car on a drive. It should re set itself. This happened to me, and that is what I did. Link to comment Share on other sites More sharing options...
GrabberO Posted May 3, 2007 Author Report Share Posted May 3, 2007 Take a look on your Door piller for the stock tire pressure reccomendation and follow that. It is 32 or 33 if I remember correctly...but check it out. Fill up the tires to that. Then take the car on a drive. It should re set itself. This happened to me, and that is what I did. Thanks Grabber......want to avoid taking it to the dealer!! Link to comment Share on other sites More sharing options...
Grabber Posted May 3, 2007 Report Share Posted May 3, 2007 Thanks Grabber......want to avoid taking it to the dealer!! I hear ya...now go look at that tire pressure sticker on the door piller and report back, and that's an order. Link to comment Share on other sites More sharing options...
whazen1 Posted May 3, 2007 Report Share Posted May 3, 2007 The correct tire pressure for our cars is 35PSI front and rear. The senser will usually come on when the tire is 9 lbs low which as you know is about 25% underflated. When you put the correct air in and drive it around the block, it will reset. I would never recommend counting on the sensor as when the tire is a couple of pounds low, there is increased heat build up and the tire can wear from the inside. If your sensor came on, I would look at the tire very carefully to see if it has a nail or screw in it. Unless you have never checked the air pressure or did not check it since getting the car, something made it lose a bunch of air. Link to comment Share on other sites More sharing options...
COBRA CRUIZER Posted May 3, 2007 Report Share Posted May 3, 2007 Check your tires after the beast sit over night, using a digital air pressure gauge. This should help. Link to comment Share on other sites More sharing options...
GrabberO Posted May 3, 2007 Author Report Share Posted May 3, 2007 I may have an issue with the sensor. My right front rim and tire were replaced after delivery due to a chip in the rim. It was determined that it left AAI with the chip as they did a photo shoot of my car just prior to its release from the plant. I will check the pressure and follow your instructions..... Thanks everyone!! Link to comment Share on other sites More sharing options...
Alloy Dave Posted May 3, 2007 Report Share Posted May 3, 2007 Couple of questions this morning…… Anyone experience a Tire Pressure Faulty Sensor warning? …..what did you do? What is your recommendation for psi on stock tires? Thanks Yes. Put air in the tire and it went away. Edit: Door placard recommends 35 psi. If your racing, you'll want to drop it down quite a bit...say to about 18-20. But for every day driving, I'd say 32-35 is ok. Link to comment Share on other sites More sharing options...
SVTpower Posted May 4, 2007 Report Share Posted May 4, 2007 I may have an issue with the sensor. My right front rim and tire were replaced after delivery due to a chip in the rim. It was determined that it left AAI with the chip as they did a photo shoot of my car just prior to its release from the plant. I will check the pressure and follow your instructions..... Thanks everyone!! sorry, but more than likely you'll be visiting your dealer for a sensor training/reset. Read my reset post in mods and tech and one about less than 2 weeks ago re: faults. Just had mine done. 5-10 minute fix. You can clear the light on the left of the dash with proper psi but the info centre fault needs your dealer and their $300 tool Link to comment Share on other sites More sharing options...
