39Mustang Posted December 29, 2016 Report Share Posted December 29, 2016 we have about 20k of track miles on our 07 SGT. replaced the tranny 2 years ago with the new MagnumXL. The 4.6 with the 2.6 KB has been going strong, but I have my sites set on a new engine in the next couple years or sooner. Can anyone say 5.2L Shelby Forged block?! 570hp! Naturally aspirated flat plane? Yes, it was just recently announced, and it will be ours someday soon. Should I wait till the 4.6 fails or do the swap sooner? only 30k miles on the original engine now so I have the time I hope. I've been waiting for that 5.2 crate engine for awhile and finally got Ford to say sometime in Spring it will be available, but the 5.2 crate engine will NOT have the flat-plane crank its exclusive to the GT350 cars only. Ford had said the 5.2 crate engine will use the Boss 302 crank but they can always change their mind until it actually goes on sale. If you've seen any online article that says the 5.2 crate will use the flat-plane crank post the link on here I say go for the swap but if you want the 5.2 then wait for it. I was never a fan of the 4.6 and its performance is limited compared to the 5.0 Coyote and 5.2 which right now you can take a Coyote slap a Whipple on there and be in the 700hp range easily and you are never getting that from the 4.6. I was all ready to do an engine swap in my 2008 GT/SC because in the last 7 years you had the 5.4 making great power and some switched to Whipple's on there and made big power. Then the 5.0 Coyote came out and they quickly found out whether Turbo or Whipplecharged the Coyote was making stupid HP, then Ford put the 5.8 w/ 662hp in the GT500 and I was like damn this sucks I wish I had this kind of power in my 2008 Shelby. My GT/SC is my favorite Mustang I own and would never sell it so instead of buying a GT500 w/ the 5.8 or a new GT350 w/ the 5.2 I decided to do an engine swap which costs a lot less than a new car. For a long time I was looking for the 5.8 from a 13-14 GT500 but they're too hard to find so I was ready to build a 5.4 until early fall when Ford said they will sell the 5.2 in a crate engine so I decided to wait and see what this engine is and its almost January so I think I can wait a couple more months. All 07-08 Shelby GT's are sleepers because they weigh what 400-500lbs less than a GT500 and that weight difference on the track is huge. Imagine our GT's with the same or more HP than the newer cars they will be like WTF dude that thing has a 4.6 how are you so fast and you just hahahaha Link to comment Share on other sites More sharing options...
TheKurgan Posted December 29, 2016 Report Share Posted December 29, 2016 I say go for the swap but if you want the 5.2 then wait for it. I was never a fan of the 4.6 and its performance is limited compared to the 5.0 Coyote and 5.2 which right now you can take a Coyote slap a Whipple on there and be in the 700hp range easily and you are never getting that from the 4.6 39, that is simply not true. I'm making over 700hp crank with the 3V without even trying very hard. Any engine you put in it is going to need race gas past that point anyway. FWIW, the 4.6 3V can make more HP than the 5.0 Coyote. The only advantage to the coyote imo, is that it's easier to make HP due to the higher compression, which can easily be changed on the 3V as well. Link to comment Share on other sites More sharing options...
39Mustang Posted December 29, 2016 Report Share Posted December 29, 2016 39, that is simply not true. I'm making over 700hp crank with the 3V without even trying very hard. Any engine you put in it is going to need race gas past that point anyway. FWIW, the 4.6 3V can make more HP than the 5.0 Coyote. The only advantage to the coyote imo, is that it's easier to make HP due to the higher compression, which can easily be changed on the 3V as well. Wasn't my opinion was going by what a couple of the top performance shops told me and there is a whole lot of technical mumbo jumbo beyond my brain involved with it, plus depends on what you are using the car for and how reliable that HP is for that specific event. How'd you get 700hp from your 4.6? Link to comment Share on other sites More sharing options...
TheKurgan Posted December 29, 2016 Report Share Posted December 29, 2016 Wasn't my opinion was going by what a couple of the top performance shops told me and there is a whole lot of technical mumbo jumbo beyond my brain involved with it, plus depends on what you are using the car for and how reliable that HP is for that specific event. How'd you get 700hp from your 4.6? Well it's a built short block to begin with so there's no worry about snapping rods which the stock 3V is known for. The Paxton can produce alot of horsepower. I'm running the smallest pulley possible so the blower is maxed out. I've run it on road courses with no issues. When I first put it on, it was overheating on the track, but I cut that plastic pos grille out and that solved it. I also have other mods like FRPP intake, throttle body, and a huge FMIC. It all does help, but if you consider I'm running FRPP hot rod cams, and stock valve train which are limitations, 700HP is doing pretty good. Doesn't hurt that Justin at VMP is one hell of a tuner. Link to comment Share on other sites More sharing options...
Kevin Patten Posted January 17, 2017 Author Report Share Posted January 17, 2017 Well it's a built short block to begin with so there's no worry about snapping rods which the stock 3V is known for. The Paxton can produce alot of horsepower. I'm running the smallest pulley possible so the blower is maxed out. I've run it on road courses with no issues. When I first put it on, it was overheating on the track, but I cut that plastic pos grille out and that solved it. I also have other mods like FRPP intake, throttle body, and a huge FMIC. It all does help, but if you consider I'm running FRPP hot rod cams, and stock valve train which are limitations, 700HP is doing pretty good. Doesn't hurt that Justin at VMP is one hell of a tuner. Did you get your T/R hood on your car? Link to comment Share on other sites More sharing options...
TheKurgan Posted January 18, 2017 Report Share Posted January 18, 2017 Did you get your T/R hood on your car? Yes, I did and I love it. It took several months for them to make it, but it almost took that long for me to get the vinyl stripes off anyway. It was worth the wait. Old hood scoop is hanging on the wall now for memorabilia. I need to get some pics up but I haven't found the perfect spot to take some pics. The guy did a good job with the design of the stripes on the hood, but he got carried away with the over spray. I'm going to have to live with it because right after I had it painted I moved 1500 miles to sunny Florida. Link to comment Share on other sites More sharing options...
Kevin Patten Posted February 1, 2017 Author Report Share Posted February 1, 2017 Signed up for the Shelby Bash #10 today - so I guess I better get this car back together! Link to comment Share on other sites More sharing options...
stngfever Posted February 2, 2017 Report Share Posted February 2, 2017 Signed up for the Shelby Bash #10 today - so I guess I better get this car back together! Link to comment Share on other sites More sharing options...
Kevin Patten Posted March 13, 2017 Author Report Share Posted March 13, 2017 Took the GT500 to the Bash - only got one check engine light - code for lean bank 1 - image that. Now back to the Shelby GT-R. Link to comment Share on other sites More sharing options...
Torch40 Posted March 14, 2017 Report Share Posted March 14, 2017 Fun times on the track and a nice run back home with you and TD Link to comment Share on other sites More sharing options...
Kevin Patten Posted April 6, 2017 Author Report Share Posted April 6, 2017 Next stop - AED for tuning - Link to comment Share on other sites More sharing options...
Lynno Posted April 7, 2017 Report Share Posted April 7, 2017 Are you going to make it to Thunder Hill in two weeks? I will be there is support not driving this time Link to comment Share on other sites More sharing options...
Kevin Patten Posted April 8, 2017 Author Report Share Posted April 8, 2017 Yes, if all goes good at AED then we are going straight there to the track. Link to comment Share on other sites More sharing options...
Kevin Patten Posted April 18, 2017 Author Report Share Posted April 18, 2017 Just received the new livery decals for the car - "TEAM SHELBY RACING" - Thanks Bob Zinzell ! Link to comment Share on other sites More sharing options...
Shelby Nick Posted April 18, 2017 Report Share Posted April 18, 2017 They look great! I need to get a pair for my car! Link to comment Share on other sites More sharing options...
Kevin Patten Posted May 8, 2017 Author Report Share Posted May 8, 2017 Finally some photos with a file size small enough to go on this. Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted May 9, 2017 Report Share Posted May 9, 2017 looks fantastic, thanks for sharing Link to comment Share on other sites More sharing options...
Kevin Patten Posted May 25, 2017 Author Report Share Posted May 25, 2017 Just signed up for the NORCAL SAAC Mini-Nats event at Sonoma Raceway in August. Should be fun! Link to comment Share on other sites More sharing options...
Cali_KR Posted July 8, 2017 Report Share Posted July 8, 2017 Just signed up for the NORCAL SAAC Mini-Nats event at Sonoma Raceway in August. Should be fun! Looking forward to it as always, especially now with the new stable mate Link to comment Share on other sites More sharing options...
Kevin Patten Posted August 9, 2017 Author Report Share Posted August 9, 2017 Had a blast at Mini-Nats 32 Link to comment Share on other sites More sharing options...
Kevin Patten Posted August 14, 2017 Author Report Share Posted August 14, 2017 Even had competition driving home! Link to comment Share on other sites More sharing options...
Cali_KR Posted August 14, 2017 Report Share Posted August 14, 2017 20638214_10212011141107257_4198110508449772021_n.jpg Even had competition driving home! Winged wonders...even on the trailers! Link to comment Share on other sites More sharing options...
sgt1020 Posted October 2, 2017 Report Share Posted October 2, 2017 It's been quite some time since I've posted on here... but thought I'd return with some interesting news. SGT1020 has been hitting the track since 2014. She's now being converted to a full blown caged race car to join our Boss 302R "Thor" in the stable as a serious piece of hardware. Thought I'd post up some recent pictures for everyone to enjoy, and so that everyone can see that there's other Shelby's out there that would make Carroll proud Link to comment Share on other sites More sharing options...
sgt1020 Posted October 2, 2017 Report Share Posted October 2, 2017 Here's a few more... Link to comment Share on other sites More sharing options...
sgt1020 Posted October 2, 2017 Report Share Posted October 2, 2017 Our Boss 302R Link to comment Share on other sites More sharing options...
Kevin Patten Posted October 2, 2017 Author Report Share Posted October 2, 2017 It's been quite some time since I've posted on here... but thought I'd return with some interesting news. SGT1020 has been hitting the track since 2014. She's now being converted to a full blown caged race car to join our Boss 302R "Thor" in the stable as a serious piece of hardware. Thought I'd post up some recent pictures for everyone to enjoy, and so that everyone can see that there's other Shelby's out there that would make Carroll proud WOW Brandon ! You've stepped up to the plate on the SGT! Looks great! Link to comment Share on other sites More sharing options...
sgt1020 Posted October 2, 2017 Report Share Posted October 2, 2017 Thanks!! Here's a few more pics... Link to comment Share on other sites More sharing options...
mach 1 1970 Posted October 8, 2017 Report Share Posted October 8, 2017 Thanks!! Here's a few more pics... Awesome car for sure. Keep the pictures coming. Link to comment Share on other sites More sharing options...
Kevin Patten Posted October 17, 2017 Author Report Share Posted October 17, 2017 Attended the NORCAL SAAC Fall Classic with some fellow Team Shelby members at Thunderhill Raceway in Willows, Calif. - Fun times! Link to comment Share on other sites More sharing options...
Kevin Patten Posted January 23, 2018 Author Report Share Posted January 23, 2018 Been a while ... Link to comment Share on other sites More sharing options...
