Carl Reichelt Posted February 12, 2013 Report Share Posted February 12, 2013 In trunk of my new 2013 GT 500 convertible I found a box with a black spoiler Or front air dam can anybody tell me what this is do I install this and where ? Link to comment Share on other sites More sharing options...
jerseygator Posted February 12, 2013 Report Share Posted February 12, 2013 Splitter? Take a pic.... Link to comment Share on other sites More sharing options...
WJinLV Posted February 12, 2013 Report Share Posted February 12, 2013 Its an extra 3 piece splitter that can be installed under the existing front splitter. I installed mine last week...easy to follow instructions. Lift car or drive up on ramps. Use 7mm socket to remove the front row retaining screws. Install middle section first, then sides. Make sure front edges are aligned before final tightening of screws. Some metal edge biter clips can also be installed. Lowers front corners almost 2" so know your curbs, driveways etc. Link to comment Share on other sites More sharing options...
Don Johnston Posted February 12, 2013 Report Share Posted February 12, 2013 Shouldn't this be on the GT500 page, not the GT350 section? Link to comment Share on other sites More sharing options...
Jer Posted February 13, 2013 Report Share Posted February 13, 2013 Its an extra 3 piece splitter that can be installed under the existing front splitter. I installed mine last week...easy to follow instructions. Lift car or drive up on ramps. Use 7mm socket to remove the front row retaining screws. Install middle section first, then sides. Make sure front edges are aligned before final tightening of screws. Some metal edge biter clips can also be installed. Lowers front corners almost 2" so know your curbs, driveways etc. And don't go anywhere with speed bumps! Jer Link to comment Share on other sites More sharing options...
mikeljgt500kr Posted February 13, 2013 Report Share Posted February 13, 2013 Why wasn't it installed at the factory? Is it installed if you do museum delivery? Link to comment Share on other sites More sharing options...
shelbymotorsports Posted February 13, 2013 Report Share Posted February 13, 2013 Why wasn't it installed at the factory? Is it installed if you do museum delivery? Railcar & truck transporter clearance issues. Steve Link to comment Share on other sites More sharing options...
mikeljgt500kr Posted February 13, 2013 Report Share Posted February 13, 2013 Railcar & truck transporter clearance issues. Steve So it will be installed if you pick it up in 'Vegas on museum delivery? Link to comment Share on other sites More sharing options...
shelbymotorsports Posted February 13, 2013 Report Share Posted February 13, 2013 So it will be installed if you pick it up in 'Vegas on museum delivery? It would be best to check directly with the sales department. Installed or uninstalled, either way they will accommodate you. Steve Link to comment Share on other sites More sharing options...
Carl Reichelt Posted February 17, 2013 Author Report Share Posted February 17, 2013 In trunk of my new 2013 GT 500 convertible I found a box with a black spoiler Or front air dam can anybody tell me what this is do I install this and where ? Did I ask this question In the wrong area, did I post in the wrong area New To me thank you all Reply about the spoiler kit again thanks Rick Link to comment Share on other sites More sharing options...
