CHEVY2SHELBY Posted January 29, 2013 Report Share Posted January 29, 2013 Hey guys, I just had my oil changed and when I checked the rear diff fluid the colouring was fine but there was a bit of metal shavings in there. Ive only got 26,000 miles on it. Is that normal for a change already? Link to comment Share on other sites More sharing options...
Larry T Posted January 29, 2013 Report Share Posted January 29, 2013 No it isn't ... but those may be some hard miles Here is the maintenance booklet http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=2006&make=Ford&model=Mustang But if you are concerned, change it, better safe then sorry. Link to comment Share on other sites More sharing options...
07SGT Posted January 30, 2013 Report Share Posted January 30, 2013 I would document with your Ford Dealer asap. Have the fluid and shavings analyzed and have the clearances for the ring and pinion checked immediately. Link to comment Share on other sites More sharing options...
Steve.Madrid Posted February 1, 2013 Report Share Posted February 1, 2013 Great question, my '08 has 16,500 right now and I am planning on changing all the fluids (rear diff, brake, radiator, transmission and of course engine) at 20K. I plan on switching everything over to Royal Purple products. Yes, I know everyone has a preference and I like RP. Been using it in the engine since 8,000 miles. So when draining, should I drain it through some sort of paper strainer to check for shavings? Should I keep a portion of the fluid for analysis? If so, how much? Thanks in advance for the info. Link to comment Share on other sites More sharing options...
CHEVY2SHELBY Posted February 1, 2013 Author Report Share Posted February 1, 2013 Would it make any difference if i upgraded to 3.73 or 4.10 rear end or would the clearance on the ring and pinion still have to be checked Link to comment Share on other sites More sharing options...
07SGT Posted February 2, 2013 Report Share Posted February 2, 2013 If you are installing a new ring and a new pinion the clearances would have to be set when installed. I would just make sure that all the metal shavings are removed. You might want to see if there is a warranty for the new products if installed by a Ford dealer. Is there any reason the old ring and pinion might have been damaged or the angle changed? Link to comment Share on other sites More sharing options...
CHEVY2SHELBY Posted February 4, 2013 Author Report Share Posted February 4, 2013 Not that I know of no Link to comment Share on other sites More sharing options...
