ilmor Posted March 10, 2013 Author Report Share Posted March 10, 2013 From the manufacturer: The plastic coupler and PCV valve is installed on the driver’s side of the engine. The plastic coupler is cut and then pressed onto the end of the provided valve. The assembly then goes in line between the intake fitting and the fitting on the cover. See pix attached below. A PDF document of these instructions will be uploaded here shortly, and included in the box going forward. Sorry for any inconvenience! Jer This (the driver side hose) needs new hose also, such as was provided for the passenger side, but a larger size. I'm not sure what size. The existing hose is a shrink-fit plastic and won't adapt properly to the end fittings, PCV and other plastic fitting. I did get the passenger side done today, but now I'm stuck at the driver side. Link to comment Share on other sites More sharing options...
Jer Posted March 10, 2013 Report Share Posted March 10, 2013 This (the driver side hose) needs new hose also, such as was provided for the passenger side, but a larger size. I'm not sure what size. The existing hose is a shrink-fit plastic and won't adapt properly to the end fittings, PCV and other plastic fitting. I did get the passenger side done today, but now I'm stuck at the driver side. Bob, you do use the existing hose. It's a tight fit, yes. I'm finalizing the Instructioon Sheet with the two new additions, but here is the gist of the side you're having trouble with: PCV hose modification: Remove foam wrapping from PCV hose. Cut the PCV hose 3-½" from the straight connection end (see diagram). Cut a 1-1/8" section out from the first cut (the PCV valve will take the place of the this section of hose). Cut the NAPA plastic hose connector 15/16" from the end (see diagram). This short piece with the barb will adapt up the PCV valve to the proper hose diameter. Using a heat gun, warm the barbed piece of the connector you removed and press it all the way on to the small end of the PCV valve. The PCV valve will be inserted in-line of the hose with the flow direction arrows (stamped in the PCV valve) pointing toward the intake manifold (the small diameter end of the PCV valve is the end that points toward the intake). Using a heat gun, warm the hose end with the straight coupling and press the PCV valve in all the way (up to the PCV valve shoulder). Using the heat gun, warm the other half of the hose end and press in the PCV valve (end with the plastic barb adapter) all the way to the shoulder. Jer Link to comment Share on other sites More sharing options...
SGT0128 Posted March 11, 2013 Report Share Posted March 11, 2013 Cam covers installed. LOVE'EM!! Link to comment Share on other sites More sharing options...
Jer Posted March 11, 2013 Report Share Posted March 11, 2013 Cam covers installed. LOVE'EM!! Nice! Jer Link to comment Share on other sites More sharing options...
ilmor Posted March 11, 2013 Author Report Share Posted March 11, 2013 Jer I finished also! Now All I need is a dry clean road :-( Link to comment Share on other sites More sharing options...
Jer Posted March 11, 2013 Report Share Posted March 11, 2013 Good to hear it! Jer Link to comment Share on other sites More sharing options...
yoggiebhr Posted March 11, 2013 Report Share Posted March 11, 2013 Looks fantastic! Link to comment Share on other sites More sharing options...
ilmor Posted March 11, 2013 Author Report Share Posted March 11, 2013 Just took this w the iPhone... Link to comment Share on other sites More sharing options...
William Rodgers Posted March 11, 2013 Report Share Posted March 11, 2013 Looks Great!!!! Ilmor you are one patient Guy, hats off to you for taking this on yourself!!!!!! Link to comment Share on other sites More sharing options...
ilmor Posted March 11, 2013 Author Report Share Posted March 11, 2013 Thanks carnut...it's helps to have the winter to do it LOL! Link to comment Share on other sites More sharing options...
JT93 Posted March 11, 2013 Report Share Posted March 11, 2013 Ilmor, who's signature is on your fuse box cover? Link to comment Share on other sites More sharing options...
ilmor Posted March 11, 2013 Author Report Share Posted March 11, 2013 Ilmor, who's signature is on your fuse box cover? Roger Sorel Link to comment Share on other sites More sharing options...
Jer Posted March 12, 2013 Report Share Posted March 12, 2013 Roger Sorel Roger was an important figure in Shelby history, good on ya! Jer Link to comment Share on other sites More sharing options...
ilmor Posted March 12, 2013 Author Report Share Posted March 12, 2013 Roger was an important figure in Shelby history, good on ya! Jer I was at the Tasca Mustang event in 2010 and he was there. I asked him if he'd mind signing my fuse box cover. I think he signed mine, QuadCam's and Secondo's that day.... Link to comment Share on other sites More sharing options...
Lgs ShelbyGT Posted December 21, 2016 Report Share Posted December 21, 2016 Bringing up this old thread, as I have a set of these cam covers on the way Did anyone receive the PDF instructions that Jer was compiling? If yes, please let me know Thanks Lg Link to comment Share on other sites More sharing options...
ilmor Posted December 21, 2016 Author Report Share Posted December 21, 2016 Bringing up this old thread, as I have a set of these cam covers on the way Did anyone receive the PDF instructions that Jer was compiling? If yes, please let me know Thanks Lg I usually save everything like that but do not find a pdf for this in my files. I'll check my garage later; if I have a hard copy I'll scan it for you. Link to comment Share on other sites More sharing options...
MyBlueHeaven Posted December 22, 2016 Report Share Posted December 22, 2016 Pulled the PDF from the Moroso site for what they have. All it gives is the information on modifying the PCV hose. attached it in case you didn't have it already. The removal and installation of the valve covers should be the same for any set of replacement covers. Am has customer submitted instructions on their ford racing valve covers page u can print out. Hope this helps Jeff Moroso 3v68388_inst.pdf Link to comment Share on other sites More sharing options...
EL SHELBY Posted December 23, 2016 Report Share Posted December 23, 2016 It's kinda funny, I bought a set for myself, but have not found the time to install them. Once I put them on, I'll upload photos... they are GORGEOUS. Jer Same here. I've been sitting on them for a couple years now along with a pile of other parts. Link to comment Share on other sites More sharing options...
ilmor Posted December 23, 2016 Author Report Share Posted December 23, 2016 Same here. I've been sitting on them for a couple years now along with a pile of other parts. You and Jer need to do it. Makes the engine look so awesome! Link to comment Share on other sites More sharing options...
Jer Posted December 23, 2016 Report Share Posted December 23, 2016 I did mine years ago! Old post! LOL... The Moroso instructions are all that is needed. Link to comment Share on other sites More sharing options...
ilmor Posted December 24, 2016 Author Report Share Posted December 24, 2016 I did mine years ago! Old post! LOL... The Moroso instructions are all that is needed. Link to comment Share on other sites More sharing options...
Jer Posted December 24, 2016 Report Share Posted December 24, 2016 Link to comment Share on other sites More sharing options...
Lgs ShelbyGT Posted December 25, 2016 Report Share Posted December 25, 2016 I appreciate everyone's comments Thanks! Now to purchase new gaskets and get it done Link to comment Share on other sites More sharing options...
EL SHELBY Posted December 26, 2016 Report Share Posted December 26, 2016 I did mine years ago! Old post! LOL... The Moroso instructions are all that is needed. Oh WOW! I really am late to the game! I better get caught up soon! Link to comment Share on other sites More sharing options...
EL SHELBY Posted December 26, 2016 Report Share Posted December 26, 2016 Did notice the stores has a set available on ebay for $599.99. I think I paid around $700. Link to comment Share on other sites More sharing options...
Lgs ShelbyGT Posted January 1, 2017 Report Share Posted January 1, 2017 Couple questions on installing the covers: When you guys installed the Shelby cam covers did you use new gaskets or reuse the originals from the stock covers? Just the allen head fasteners and flat washers, no other seals, o-rings or the like, correct? Also, wondering about the merit of installing new spark plugs given everything is already apart Only 12k since new plugs when I installed the supercharger but it was the spring of 2011 Primarily considering it due to the 2-piece spark plug Thanks as always for your help Larry Link to comment Share on other sites More sharing options...
Jer Posted January 1, 2017 Report Share Posted January 1, 2017 Couple questions on installing the covers: When you guys installed the Shelby cam covers did you use new gaskets or reuse the originals from the stock covers? Just the allen head fasteners and flat washers, no other seals, o-rings or the like, correct? Also, wondering about the merit of installing new spark plugs given everything is already apart Only 12k since new plugs when I installed the supercharger but it was the spring of 2011 Primarily considering it due to the 2-piece spark plug Thanks as always for your help Larry I had the FRPP covers on my car, transferred all the stuff, gaskets and all, right over to the SPP covers. As for spark plugs, if you have the originals, yes, good time to swap them out. Be careful, as you may have heard, the stock plugs have breakage issues. Soak with solvent, take your time, etc... Jer Link to comment Share on other sites More sharing options...
ilmor Posted January 1, 2017 Author Report Share Posted January 1, 2017 Couple questions on installing the covers: When you guys installed the Shelby cam covers did you use new gaskets or reuse the originals from the stock covers? I checked the old gaskets; they looked brand new so I reused them. Just the allen head fasteners and flat washers, no other seals, o-rings or the like, correct? Correct. Also, wondering about the merit of installing new spark plugs given everything is already apart Only 12k since new plugs when I installed the supercharger but it was the spring of 2011 Primarily considering it due to the 2-piece spark plug I still have my original plugs. The car runs fine to me so I've chosen not to spend the time and money, personally. Thanks as always for your help Larry Link to comment Share on other sites More sharing options...
