ilmor Posted January 20, 2013 Report Share Posted January 20, 2013 Getting ready to install. Going to take my time to do it over a few weekends.... http://www.shelbystore.com/product-p/s5mr-6582-b.htm Quote Link to comment Share on other sites More sharing options...
jmn444 Posted January 20, 2013 Report Share Posted January 20, 2013 Nice! Quote Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted January 20, 2013 Report Share Posted January 20, 2013 Those will look sharp. Post the progress with pictures Quote Link to comment Share on other sites More sharing options...
IASHELBYGT Posted January 21, 2013 Report Share Posted January 21, 2013 Very nice. Those will look great! Quote Link to comment Share on other sites More sharing options...
07SGT Posted January 21, 2013 Report Share Posted January 21, 2013 (edited) Those are beautiful. Please post photos and do you mind if I (we) ask the cost? Just think how beautiful those covers would be in you knew they were covering Hot Rod Cams also.!!!!!!!!!!!!!!!! Edited January 21, 2013 by 07SGT Quote Link to comment Share on other sites More sharing options...
ilmor Posted January 21, 2013 Author Report Share Posted January 21, 2013 Those are beautiful. Please post photos and do you mind if I (we) ask the cost? Just think how beautiful those covers would be in you knew they were covering Hot Rod Cams also.!!!!!!!!!!!!!!!! No problem! From the Shelby Store... http://www.shelbystore.com/product-p/s5mr-6582-b.htm Yeah those cams would be nice too...but for my emissions laws.... Quote Link to comment Share on other sites More sharing options...
Carnut12 Posted January 22, 2013 Report Share Posted January 22, 2013 I can not wait to see those installed, very nice indeed. Have you ever completed a post comparing you fairly New Mustang against the Shelby GT? Just curious on your thoughts between the two. Quote Link to comment Share on other sites More sharing options...
ilmor Posted January 23, 2013 Author Report Share Posted January 23, 2013 I can not wait to see those installed, very nice indeed. Have you ever completed a post comparing you fairly New Mustang against the Shelby GT? Just curious on your thoughts between the two. I don't think I've started a specific topic regarding the two cars. I'll have to do that! I've managed to start on the new covers - got the car in place and the garage set up, and removed a couple of things. Also came across this nice guide on Mustang Monthly... http://www.mustangmonthly.com/techarticles/mump_0610_ford_mustang_gt_valve_cover/viewall.html Quote Link to comment Share on other sites More sharing options...
ilmor Posted January 24, 2013 Author Report Share Posted January 24, 2013 YIKES! Quote Link to comment Share on other sites More sharing options...
SGT0128 Posted January 24, 2013 Report Share Posted January 24, 2013 Exactly what I thought. I bought the same cam covers. So far they are sitting in the box in my garage. I'm not sure if I have the skills or patients to do the job. Quote Link to comment Share on other sites More sharing options...
ilmor Posted January 25, 2013 Author Report Share Posted January 25, 2013 I'll be working on it more this weekend and I'lll post some progress photos. I've removed the CAI and strut bar. I've got a nice work light shining on the patient. Quote Link to comment Share on other sites More sharing options...
Carnut12 Posted January 25, 2013 Report Share Posted January 25, 2013 I had Tasca Install mine when I got the GT/SC Package. Good luck Quote Link to comment Share on other sites More sharing options...
richard m.switzer Posted January 25, 2013 Report Share Posted January 25, 2013 Just saying ,,drive side kinda easy ,,pass side a pain in the butt ,, you might have to remove the battery to get to bolts on pass side and makes it easyer too ,,with the battery out ,and some plastic pull ties to hold back up toward the intake / fuel rail the big stock black wire cable that runs across the pass side valve cover to the computer box under the hood ,,, like I said ,,drive side easy,,, but the pass side is a whole different story ,, " been there ,done that ",,,easy way is to unplug the coil packs on the pass side and plastic pull tie up the big black wire cable / pull back toward the fuel rail ,,will hold it out of the way far enough so you can get the stock cover out and the new one in ,,,and be sure ,make sure the gasket is set right ,on both sides , " no leaks ",,, you can re-use the stock Ford one ,, GOOD LUCK ,, ,, can't wait to see the pictures ,,,,,, Quote Link to comment Share on other sites More sharing options...
richard m.switzer Posted January 25, 2013 Report Share Posted January 25, 2013 (edited) Just saying ,,drive side kinda easy ,,pass side a pain in the butt ,, you might have to remove the battery to get to bolts on pass side and makes it easyer too ,,with the battery out ,and some plastic pull ties to hold back up toward the intake / fuel rail the big stock black wire cable that runs across the pass side valve cover to the computer box under the hood ,,, like I said ,,drive side easy,,, but the pass side is a whole different story ,, " been there ,done that ",,,easy way is to unplug the coil packs on the pass side and plastic pull tie up the big black wire cable / pull back toward the fuel rail ,,will hold it out of the way far enough so you can get the stock cover out and the new one in ,,,and be sure ,make sure the gasket is set right ,on both sides , " no leaks ",,, you can re-use the stock Ford one ,, GOOD LUCK ,, ,, can't wait to see the pictures ,,,,,, ,,,,,,,,,,and you will have to remove the " Tower brace " too . Edited January 25, 2013 by richard m.switzer Quote Link to comment Share on other sites More sharing options...
ilmor Posted January 25, 2013 Author Report Share Posted January 25, 2013 Thanks for the tips all! My daughter is going to assist me in holding back the wires, etc. Quote Link to comment Share on other sites More sharing options...
07SGT Posted January 25, 2013 Report Share Posted January 25, 2013 Looks like a good step-by-step write up. Just go slow and take it a step at a time. A journey of a thousand miles begins with a single step. Do you re-use the bolts? Quote Link to comment Share on other sites More sharing options...
ilmor Posted January 26, 2013 Author Report Share Posted January 26, 2013 Im live on UStream! Employee Engagement Quote Link to comment Share on other sites More sharing options...
ilmor Posted January 26, 2013 Author Report Share Posted January 26, 2013 Got the driver side done... Quote Link to comment Share on other sites More sharing options...
Steve.Madrid Posted January 27, 2013 Report Share Posted January 27, 2013 That is really good looking. How about a picture pulled back a little to see how it dresses up the engine as a whole? I have really been considering this as a mod but have been looking at the "Ford Racing" blue covers, but now these have definately caught my eye. Quote Link to comment Share on other sites More sharing options...
07SGT Posted January 27, 2013 Report Share Posted January 27, 2013 any leaks? Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted January 27, 2013 Report Share Posted January 27, 2013 Man that looks good. Quote Link to comment Share on other sites More sharing options...
ilmor Posted January 27, 2013 Author Report Share Posted January 27, 2013 any leaks? I ran it for a little while (too snowy/salty outside to drive it) and checked...no leaks (yet).... Quote Link to comment Share on other sites More sharing options...
ilmor Posted January 27, 2013 Author Report Share Posted January 27, 2013 That is really good looking. How about a picture pulled back a little to see how it dresses up the engine as a whole? I have really been considering this as a mod but have been looking at the "Ford Racing" blue covers, but now these have definately caught my eye. How's this shot. I think more of the cover shows on the passenger side (less stuff in the way), which I have not done yet. These were also taken in my garage, at night under a light, so I would imagine that a daytime car show would look even better. Quote Link to comment Share on other sites More sharing options...
ilmor Posted January 27, 2013 Author Report Share Posted January 27, 2013 Having an issue but does not appear to be serious. Check out this thread / question which I've posted on the SPP forum. Everyone in the know feel free to chime in! http://www.teamshelby.com/forums/index.php/topic/79419-installing-46l-racing-valve-covers-have-a-question/ Quote Link to comment Share on other sites More sharing options...
07SGT Posted January 27, 2013 Report Share Posted January 27, 2013 Just curious, since those are "Racing" valve covers do they make a provision for a PCV valve? Quote Link to comment Share on other sites More sharing options...
ilmor Posted January 28, 2013 Author Report Share Posted January 28, 2013 Apparently, as a pcv valve was provided with the covers. Just curious, since those are "Racing" valve covers do they make a provision for a PCV valve? Explained in the other thread - http://www.teamshelb...ave-a-question/ - I'm trying to keep that question separate from this thread for now. Quote Link to comment Share on other sites More sharing options...
Steve.Madrid Posted February 1, 2013 Report Share Posted February 1, 2013 How's this shot. I think more of the cover shows on the passenger side (less stuff in the way), which I have not done yet. These were also taken in my garage, at night under a light, so I would imagine that a daytime car show would look even better. Great shot, thanks for taking it. I definately think it adds alot to the overall asthetic of the engine bay. Quote Link to comment Share on other sites More sharing options...
ilmor Posted February 2, 2013 Author Report Share Posted February 2, 2013 I'm going to continue with installation of the passenger side this weekend, now that my question regarding the PCV has been answered. Quote Link to comment Share on other sites More sharing options...
ilmor Posted February 2, 2013 Author Report Share Posted February 2, 2013 Ready to pull the passenger side valve cover - wondering how I'm gonna get it past all these cables....I've removed / loosened all that I reasonably can at this point.... Quote Link to comment Share on other sites More sharing options...
ilmor Posted February 2, 2013 Author Report Share Posted February 2, 2013 Not so bad...took about 5 minutes to wiggle it out...move it out towards the front of the car while pushing the wires away (gently)... Quote Link to comment Share on other sites More sharing options...
