2nd2none Posted January 13, 2013 Report Share Posted January 13, 2013 I plan on changing out the rear end of my 2010 in favor of the 2013. Bumper, lights, mufflers. I read that the 2013 also have a higher flowing stock catalytic converter and the exhaust manifolds have a larger diameter as well. I'm wondering if I would be able to just take a complete exhaust including the manifolds from a 2013 and have it be a direct bolt on to my 2010. Anyone happen to know? Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted January 13, 2013 Report Share Posted January 13, 2013 I plan on changing out the rear end of my 2010 in favor of the 2013. Bumper, lights, mufflers. I read that the 2013 also have a higher flowing stock catalytic converter and the exhaust manifolds have a larger diameter as well. I'm wondering if I would be able to just take a complete exhaust including the manifolds from a 2013 and have it be a direct bolt on to my 2010. Anyone happen to know? I believe if you use a *complete* exhaust, it would work. "Complete" as in, from the exhaust manifolds to the muffler tips. They started using a larger diameter system in.....2011??? And then the dual tips in 2013 (and most likely, hi-flow CAT's). Phill Quote Link to comment Share on other sites More sharing options...
Tob Posted May 26, 2013 Report Share Posted May 26, 2013 I plan on changing out the rear end of my 2010 in favor of the 2013. Bumper, lights, mufflers. I read that the 2013 also have a higher flowing stock catalytic converter and the exhaust manifolds have a larger diameter as well. I'm wondering if I would be able to just take a complete exhaust including the manifolds from a 2013 and have it be a direct bolt on to my 2010. Anyone happen to know? Manifold diameter is unchanged and the same from '07-'14. The '13/'14 catcons mirror the '11/'12 units aside from the bonding cement along with utilizing 304 stainless (for a portion of the converter body) as opposed to 409 stainless. They flow the same, '11-'14. Quote Link to comment Share on other sites More sharing options...
