NMAv Posted December 4, 2012 Report Share Posted December 4, 2012 Does anyone have directions for this process. I haven't looked at things but wanted to get some documentation before starting. Also, how long should it take? Quote Link to comment Share on other sites More sharing options...
Glenn Greenwell Posted December 4, 2012 Report Share Posted December 4, 2012 Drop Springer (John) a pm, he took his rear sway bar off to lube it several months ago. GG Quote Link to comment Share on other sites More sharing options...
ingram4868 Posted December 4, 2012 Report Share Posted December 4, 2012 Still have mine in the garage waiting on warmer weather for projects. Quote Link to comment Share on other sites More sharing options...
msb64 Posted December 6, 2012 Report Share Posted December 6, 2012 Very simple mod, the hardest part is pretty much jacking the back end up to get at it. Put the back end up on jack stands and then remove the rear wheels. You need to unbolt the swaybar at the rear end, swing it up out of the way and tie it up with something, then trim off the lower parts of the mounts as per the instructions. I took my time and did it by hand with a hacksaw, and then cleaned the edges up with a hand file. I painted the newly exposed metal to match the rest of my painted rear end, to keep things looking nice. Bolt on the new relocation brackets, and then bolt the swaybar to the relocation brackets. With hand tools in a home garage and painting, allow about 2 hours at a leasurely pace. I used the BMR brackets to help fit 325/15 drag radials on the car. In my case I also removed the body mounted bump stops, and installed zombeasts bumpstop relocation brackets. Plenty of room back there now. BMR installation instructions are available here: www.cjponyparts.com/images/art/install_HW2352.pdf Quote Link to comment Share on other sites More sharing options...
