Wayne in NJ Posted November 30, 2012 Report Share Posted November 30, 2012 ...the vertical switch/levers, how do they work? (Fan is a horizontal one, above them...but you probably know that)! Link to comment Share on other sites More sharing options...
jmn444 Posted November 30, 2012 Report Share Posted November 30, 2012 They just move cables that open and close flaps in the heater box to control mix of hot an cold air sourses and direction of flow. Link to comment Share on other sites More sharing options...
Denstang65 Posted November 30, 2012 Report Share Posted November 30, 2012 Even though I do not have A/C, I know the far right lever in the up position allows heat to blow at feet level. That lever in the down position blows heat out on top of the dash as a defroster on the windshield. Link to comment Share on other sites More sharing options...
Wayne in NJ Posted November 30, 2012 Author Report Share Posted November 30, 2012 Thanks! Which one is temp control? (The car is in storage about 45 minutes from here, and am going on memory. There are 3 vertical levers, or only two? If two, THAT answers the temp question)! Not that you can see it well in this shot...but here's the interior: Link to comment Share on other sites More sharing options...
Denstang65 Posted December 1, 2012 Report Share Posted December 1, 2012 This is what it says regarding to these controls in my 65-73 Mustang recognition guide; The heat lever "left" controls the path of the air in the right ventilating duct. The temp "middle" lever controls the amount of warm fresh air discharged from the heater. The def lever "right" controls the path of the air coming out of the heater. Hope the info helps. Link to comment Share on other sites More sharing options...
Wayne in NJ Posted December 1, 2012 Author Report Share Posted December 1, 2012 This is what it says regarding to these controls in my 65-73 Mustang recognition guide; The heat lever "left" controls the path of the air in the right ventilating duct. The temp "middle" lever controls the amount of warm fresh air discharged from the heater. The def lever "right" controls the path of the air coming out of the heater. Hope the info helps. Thanks!! Link to comment Share on other sites More sharing options...
