bergenfelter Posted October 7, 2012 Report Share Posted October 7, 2012 1. Any advice on a set of aftermarket brake pads? The car will see a couple of track days per year and the rest street driving. The brake dust on the factory pads is TERRIBLE. 2. I will be swapping out the brake fluid with ATI SuperBlue - are there any special bleedout procedures with Ford ABS (This is my first Mustang)? I am planning on using a vacuum extractor and keeping the reservoir full - so I will not be introducing any air into the system. Thanks! Quote Link to comment Share on other sites More sharing options...
Snoopy49 Posted October 8, 2012 Report Share Posted October 8, 2012 Remember when you change the brake fluid, you are also changing the clutch fluid. So make sure you also purge and bleed the clutch line and actuator. Quote Link to comment Share on other sites More sharing options...
Snoopy49 Posted October 8, 2012 Report Share Posted October 8, 2012 Clutch/Brake Master Cylinder question - Bleeding the clutch Quote Link to comment Share on other sites More sharing options...
bergenfelter Posted October 9, 2012 Author Report Share Posted October 9, 2012 Snoop - Thanks! Any suggestions for brake pads from the forum? Quote Link to comment Share on other sites More sharing options...
