Seabee Posted September 28, 2012 Report Share Posted September 28, 2012 Just wanted to know if anyone else has had this issue: I start the car. Everything looks/sounds good. Put it in gear, start putting power and release the clutch and it stalls because as I push the fuel pedal there is no response. Shut the car off, restart it and it is fine. Almost like the computer didn’t boot right and restarting it fixes the problem. I have had the car since JUL 2010, and have 15800 miles on it. This is the third time that this has happened, since I took ownership. Has anyone else had this happen? If so have you gotten it fixed? What was the problem? Thanks, Pete Link to comment Share on other sites More sharing options...
Torched10 Posted September 28, 2012 Report Share Posted September 28, 2012 These,are,drive by wire cars i no throttle cab le. I'm not a gearhead but did it throw off any codes on your display. If it were me id unplugg the battery for. A bit and see if the computer resets. Is it still under warranty Link to comment Share on other sites More sharing options...
Seabee Posted September 29, 2012 Author Report Share Posted September 29, 2012 Still under warranty. I understand that these cars are drive by wire. Just wanted to know of it happened to anyone else. Next time I bring it in, I'll have them look at all the codes. Works fine once I restart the car. Pete Link to comment Share on other sites More sharing options...
