elanore Posted August 28, 2012 Report Share Posted August 28, 2012 Does anybody else have this problem ?? the heat from my headers melts the Ho2 extension wires on both sides;also the traction control wires @ the tail pipe end . Should'nt there be a aluminium protective sleeve? Link to comment Share on other sites More sharing options...
dbackg Posted August 28, 2012 Report Share Posted August 28, 2012 Wow. What exhaust headers did you install ... or stock? Pics? Link to comment Share on other sites More sharing options...
shelbymotorsports Posted August 28, 2012 Report Share Posted August 28, 2012 Does anybody else have this problem ?? the heat from my headers melts the Ho2 extension wires on both sides;also the traction control wires @ the tail pipe end . Should'nt there be a aluminium protective sleeve? Who installed the headers as they are not part of the SS package. And what brand are the headers? Steve Link to comment Share on other sites More sharing options...
Robert M Posted August 28, 2012 Report Share Posted August 28, 2012 Were they installed by SM, after the SA SS conversion? R Link to comment Share on other sites More sharing options...
elanore Posted August 29, 2012 Author Report Share Posted August 29, 2012 Who installed the headers as they are not part of the SS package. And what brand are the headers? Steve Steve Sean Hyland Moorsports insal my KOOKS LONG TUBE headers with X pipe since they are the onley SA representent in CANADA !! Link to comment Share on other sites More sharing options...
elanore Posted August 29, 2012 Author Report Share Posted August 29, 2012 Wow. What exhaust headers did you install ... or stock? Pics? Sorey just cant post any pic it must be my seting !!!lol Link to comment Share on other sites More sharing options...
elanore Posted August 31, 2012 Author Report Share Posted August 31, 2012 So no one else hase this problem ??? hum ....!!!!! Link to comment Share on other sites More sharing options...
shelbymotorsports Posted August 31, 2012 Report Share Posted August 31, 2012 Have you contacted SHM to see what they say? Perhaps you need to use two extensions to get the slack needed in the wiring harness so that you can ty-wrap the harness away from the headers. You could also use some of that heat protection sleeve that is for s/p wires. See pic. Steve Link to comment Share on other sites More sharing options...
elanore Posted September 1, 2012 Author Report Share Posted September 1, 2012 Good idea four the sleeve, And yes i did contac SHM but stil waiing four his repley ,Sean is goon til the ten they tell my !!! Link to comment Share on other sites More sharing options...
elanore Posted April 27, 2013 Author Report Share Posted April 27, 2013 are these KOOKS headers and cat converters ???? Link to comment Share on other sites More sharing options...
Superswede Posted April 29, 2013 Report Share Posted April 29, 2013 I had the problem last weekend and it took fire under the car. 12SS0030 Lars Erik Link to comment Share on other sites More sharing options...
myfast70 Posted May 1, 2013 Report Share Posted May 1, 2013 Wow, that sucks! Any other damage besides the pic? Link to comment Share on other sites More sharing options...
elanore Posted May 1, 2013 Author Report Share Posted May 1, 2013 Steve Sean Hyland Moorsports insal my KOOKS LONG TUBE headers with X pipe since they are the onley SA representent in CANADA !! Just found out that my headers are not KOOKS they are American racing !!! lol Acording to the logo on the headers I had specified the Kooks at that time ........ Link to comment Share on other sites More sharing options...
Superswede Posted May 1, 2013 Report Share Posted May 1, 2013 No, the car is soon on the street again just waithing for some new hoses and elecrical wires. //Lars Erik Link to comment Share on other sites More sharing options...
Guest MTYQIN Posted May 1, 2013 Report Share Posted May 1, 2013 Elanore, I did exhaust mods last autumn and while I did not have any O2 sensor melting issues, I did experience the meltdown of the ABS sensor out back. That turned out to be caused by installer not moving sensor clear of tailpipes as he was putting things back together after the new H pipe got added to the system. Cost me a couple hundred dollars to get new sensor wired in and pipes put back up, but no problems since. Good luck getting back on the road. All the best, Quinn Link to comment Share on other sites More sharing options...
elanore Posted May 20, 2013 Author Report Share Posted May 20, 2013 Well just want to say that the car is back up and runing !!! Link to comment Share on other sites More sharing options...
areezm Posted January 22, 2014 Report Share Posted January 22, 2014 Just curious as to what was the concern with the overheating exhaust? I have one where the battery tray has completely melted including some wiring for the O2 sensors and other underbody wiring. After replacing all damaged parts, running the engine for barely 5 mins, we can see the exhaust headers glowing red. Engine coolant temp seems to be fine and fan is kicking on (atleast low speed as the CHT is not getting to 80 deg C before we have to shut it down to prevent another melt down). Any ideas? Link to comment Share on other sites More sharing options...
elanore Posted January 23, 2014 Author Report Share Posted January 23, 2014 In my case It turn out to be the 02 sensors extension wires have melt .Causing a malfunction of the 02 sensors then the car went on safe mode ,buy the time I got it to the garage her was the damages 2 02 extentions wirers 2 cat converters 1 02 sensor 1 melt down of abs wirers @ tail pipe All this to say that I had no issue last summer Link to comment Share on other sites More sharing options...
