Zeroescence Posted August 18, 2012 Report Share Posted August 18, 2012 I just finished up my Shelby Fays2 Watts Link, What a pain in the ass! It took me 5 hours. Glad I have patience. I went ahead and did it before the lowering springs as Jim Fay said it would be okay. It was a bitch to do on the SVTPP with the vented axle cover. Most adjustments have to be done before you bolt it up. The instructions that came with the kit were useless. In the manual it says to put on the bar then add the prop and arms, NOT going to happen! This thing needs to be installed twice. First time to get it all positioned and then pull the bar, prop and arms back out to get the rods measured to the same length. Then reinstall it with all the stuff tightened on the prop as the prop main bolt, prop top and bottom heim joint bolts, and the top prop driver side jam nut can not be tightened once the bar is mounted to the car. It was a bitch and a half. It makes noise. Not much but enough to annoy most. It has no squeak, just a slight knock over bumps. I made sure everything was greased up where it needed to be. It does handle better and rides alittle better. I'm not quite sure it's worth the $650 yet. I have only put 20 miles on it, so that's definitely not enough. The ass end is more stable through corners and it has almost no body roll now. Just don't like extra noise. Normally in second with the tires warm around a corner it will slide at about 25-30 mph under half throttle. Now at 35-40mph with half throttle it doesn't budge around a corner. Almost feels like my lowered evo x over dips and bumps. It is definitely better around a corner than the factory pan hard. I actually just took it all off again to put it on the bottom hole of the bar and it handled even better. To adjust it the entire thing has to be taken out and reinstalled. Again I have a lot of patience so that helped. I'll keep every one up to date as I put miles on her. Here are pics before I lowered it to the bottom hole. Quote Link to comment Share on other sites More sharing options...
Snake Handler Posted August 18, 2012 Report Share Posted August 18, 2012 You need a set of ramps! Quote Link to comment Share on other sites More sharing options...
Zeroescence Posted August 19, 2012 Author Report Share Posted August 19, 2012 You need a set of ramps! My tires are to wide for the rhino ones, and couldn't find metal ones wide enough. I trust the wheels more. Quote Link to comment Share on other sites More sharing options...
Zeroescence Posted August 21, 2012 Author Report Share Posted August 21, 2012 (edited) Well took it all off and found that one of the two machine washers was a little bigger and it was binding with the snap ring causing the bolt not to completely tighten, even though I had 100 pounds on it. What I found it would do is pivot back and forth with the prop and come slightly loose causing the popping noise after a couple bumps of loosening it up. I'm happy to say after spending 14 hours total on her she is well worth the investment. Just go into in knowing the instructions are not for our cars and will not work at all. If anyone need pointers before installing the shelby Watts link PM me and I will help you over the phone as I'm sure I'm the only on these forums with a 2013 GT500 that has this installed. Edited August 21, 2012 by Zeroescence Quote Link to comment Share on other sites More sharing options...
svt13 Posted August 21, 2012 Report Share Posted August 21, 2012 Sent you a PM Quote Link to comment Share on other sites More sharing options...
Snoopy49 Posted August 21, 2012 Report Share Posted August 21, 2012 How the FAYS2 Suspension Watts Link Works Quote Link to comment Share on other sites More sharing options...
ingram4868 Posted August 21, 2012 Report Share Posted August 21, 2012 It's sad to hear that the instructions were not sufficient to make an easy install but it is good to hear that so far you like the improved handling. And as a side benefit it is so damn good looking. Quote Link to comment Share on other sites More sharing options...
patrickshelby Posted August 21, 2012 Report Share Posted August 21, 2012 Tell us more about your conclusion after driving some more and about the noise coming from it... Quote Link to comment Share on other sites More sharing options...
