pgodden Posted April 13, 2014 Report Share Posted April 13, 2014 Thanks Norton Link to comment Share on other sites More sharing options...
Norton Posted April 13, 2014 Report Share Posted April 13, 2014 Technically, the bulbs CAN be installed without removing any panels. (You have to snake your hand/arm between the wheel well and fender, and do it "by feel".) I couldn't do it, so I dropped the underside valence. Doing so made the job a piece of cake. Highly recommended. (There are some photos on SVTP which, unfortunately, is inaccessible following a system "upgrade". When I can get back in, I'll post a link for you.) Here's the link, assuming you can get to the site... http://www.svtperformance.com/forums/showthread.php?889591-LED-Fog-Light-Bulb-Install You do NOT need to remove the lamp assemblies. Link to comment Share on other sites More sharing options...
pgodden Posted April 13, 2014 Report Share Posted April 13, 2014 Thanks Norton, Bulbs are installed, my MOD days are over.... what a weekend Side note, the bulbs from Revan (30 watt replacements) will not clip into place on the harness, the fit is tight but the retaining clip won't set seems to be quite an ugly tab inside. I used a dab of silicone to make sure the harness won't vibrate out of the bulb making me have to open it up again. They look good though. Link to comment Share on other sites More sharing options...
