wanted2b Posted May 5, 2012 Report Share Posted May 5, 2012 Need some feed back on which shifter to buy for the 2012 six speed? Thanks in advance. Link to comment Share on other sites More sharing options...
dbackg Posted May 5, 2012 Report Share Posted May 5, 2012 http://www.mgwltd.com/mustang_2010-Present.shtml Link to comment Share on other sites More sharing options...
Grabber Posted May 5, 2012 Report Share Posted May 5, 2012 https://www.speeddawg.com/ http://www.teamshelby.com/forums/index.php/topic/70892-installed-a-new-shift-knob-in-tanabananas-gt500/page__view__findpost__p__1214188 Link to comment Share on other sites More sharing options...
enormous Posted May 5, 2012 Report Share Posted May 5, 2012 I tried to order a MGW and last week was told that they are out of stock for 3 weeks. On wednesday I installed the Barton shifter and boy, this shifter is nice. $325 and free shipping. http://www.bartonindustries.com/ Link to comment Share on other sites More sharing options...
Grabber Posted May 5, 2012 Report Share Posted May 5, 2012 Need some feed back on which shifter to buy for the 2012 six speed? Thanks in advance. So you are not happy with your factory ford Racing shifter ? Or are you trying to get rid of the grind issue I see some members posting about ? Link to comment Share on other sites More sharing options...
patrickshelby Posted July 17, 2012 Report Share Posted July 17, 2012 So you are not happy with your factory ford Racing shifter ? Or are you trying to get rid of the grind issue I see some members posting about ? My 2012 is kind of hard to shift between 1st and 2nd (1000 miles now). Overall this new 2012 is hard to shift from neutral to 1st and from neutral to reverse, but those are less of a pain than from 1st to 2nd...because you're already moving... :-) I wait and pull gently on the shifter while fully depressing the clutch and giving some gas but it takes a while and a double "click clonk" 2nd gear engagement feel and noise. I was wondering if going to an aftermarket shifter like the one installed on the 12' SS would help? And if changing oil would also help some more...? Link to comment Share on other sites More sharing options...
Ecrissman Posted July 30, 2012 Report Share Posted July 30, 2012 My 2012 is kind of hard to shift between 1st and 2nd (1000 miles now). Overall this new 2012 is hard to shift from neutral to 1st and from neutral to reverse, but those are less of a pain than from 1st to 2nd...because you're already moving... :-) I wait and pull gently on the shifter while fully depressing the clutch and giving some gas but it takes a while and a double "click clonk" 2nd gear engagement feel and noise. I was wondering if going to an aftermarket shifter like the one installed on the 12' SS would help? And if changing oil would also help some more...? Mine also has 2 clicks as it engages second. You can even feel it with the motor off just sitting in the garage. I just figured thats the way it is. Link to comment Share on other sites More sharing options...
