kabal308 Posted May 1, 2012 Report Share Posted May 1, 2012 I know this is a bit of an odd topic, but does anyone know where Shelby sourced the hood mounted squirter nozzles from? SA is out of them and I had my hood resprayed during the restripe and they were removed and couldn't be reused. Link to comment Share on other sites More sharing options...
gth0007 Posted May 1, 2012 Report Share Posted May 1, 2012 You may want to contact SAI directly as at one time they did have extras. I believe the source was Gates Rubber but not sure. A near exact pair can be purchased from Discount Auto. These are a little bit more "shiney" but install exactly the same and use a plastic nut to tighten as opposed to those nasty metal clips on the original washer nozzles. I do assume you are talking about the 2006 GTH ?? Hope this helps. regards Larry, Link to comment Share on other sites More sharing options...
