AFCO HE with Fans
It should turn on whenever the H/E pump goes on. Do you have a tune? My VMP tune turns the pump on at about 60 degrees, which means it almost always runs. I don't know about the other tuners. If you don't have a tune, then it sounds like the relay trigger wire is hooked up wrong. It should be spliced into the white wire on the pump motor.
Steve
I do have a tune which was installed later in the day, but the fans ran before the tune. The HE was the first thing installed, and we did splice the wire into the white pump wire with the supplied "3 way" connecter. Also, the pump does run at the same time with the fans.
Edited by SNKBITE
  • 1 month later...
