Jmarkle24 Posted March 31, 2012 Report Share Posted March 31, 2012 Looking at getting the cragar 701c. They are 20x9 with offset +35mm with rear spacing of 6- 3/8". What tire sizes should I run with these. Link to comment Share on other sites More sharing options...
Kevin Patten Posted May 6, 2012 Report Share Posted May 6, 2012 Proper tire size for that wheel on your car is a 255/35-20. The sectional width is 10.0" ( 1" wider than rim width for straight / parrallel sidewalls ) Shoulder height is 3.5" which gives you a 27" overall diameter. Choose a tire that meets or exceeds the minimum speed and load requirements of the vehicle and look at the max. load @ max PSI on the sidewall to get an idea on where you will need to set your tire pressures at as compared to the stock tires. Refer to the sticker on the inside post of the driver's door and owners manual . Link to comment Share on other sites More sharing options...
89Saleen215 Posted May 6, 2012 Report Share Posted May 6, 2012 That's a small tire. I'd try to at least get a 20x10 on the rear and run a 295/30-20 (this won't change your speedo either). Link to comment Share on other sites More sharing options...
