07SGT Posted May 7, 2012 Author Report Share Posted May 7, 2012 Thank you very much for the ideas. And you may have given me a great idea. How about aluminum wire with plastic shield. Very, very, thin gauge wire that I could place in the hole? Link to comment Share on other sites More sharing options...
springer Posted May 7, 2012 Report Share Posted May 7, 2012 Aluminum wire should work too. Anytime you have a hole that is a little oversized, place something in it, like a wire, and it will take up the slack and allow the screw to tighten up. The same thing works with wood - done it many times. Good luck. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted May 7, 2012 Report Share Posted May 7, 2012 Aluminum wire should work too. Anytime you have a hole that is a little oversized, place something in it, like a wire, and it will take up the slack and allow the screw to tighten up. The same thing works with wood - done it many times. Good luck. I've used pieces of solder for taking up slack in holes. It's soft so it won't screw up the threaded metal. Phill Link to comment Share on other sites More sharing options...
07SGT Posted May 7, 2012 Author Report Share Posted May 7, 2012 both good suggestions. I am used to using a filler for wood or standard metal but not being restricted to aluminum. Link to comment Share on other sites More sharing options...
07SGT Posted June 9, 2012 Author Report Share Posted June 9, 2012 finally installed the screws yesterday. Used strips of a rubbery/plastic type shipping bands from a purchase I made. Cut the bands into narrow strips and inserted in the screw holes. The new screws bit in to and the strips filled the hole. apparently successful. Link to comment Share on other sites More sharing options...
