Sudguy4 Posted March 10, 2012 Report Share Posted March 10, 2012 Hey TS, My Dad and I are in the middle of the restoration on his GT350H, and have come across a few technical electrical questions... 1. Who do you guys recommend to rebuild/restore the original factory dash mounted tachometer? It works sporadically at best, and it just needs to be gone through electrically and cosmetically. 2. When the headlights are on, should the front turn signals also be on? I know when you have the switch pulled out in "park", the orange indicators are on, but when we pull the headlights full on, they go off. I've seen it both ways on other Mustangs from this vintage, and we want to make it correct. Thanks in advance for any insight/suggestions. Best, Sudguy4 Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted March 10, 2012 Report Share Posted March 10, 2012 Hey TS, My Dad and I are in the middle of the restoration on his GT350H, and have come across a few technical electrical questions... 1. Who do you guys recommend to rebuild/restore the original factory dash mounted tachometer? It works sporadically at best, and it just needs to be gone through electrically and cosmetically. 2. When the headlights are on, should the front turn signals also be on? I know when you have the switch pulled out in "park", the orange indicators are on, but when we pull the headlights full on, they go off. I've seen it both ways on other Mustangs from this vintage, and we want to make it correct. Thanks in advance for any insight/suggestions. Best, Sudguy4 Cannot help but please post some pictures if you can. Good luck Link to comment Share on other sites More sharing options...
Don Johnston Posted March 11, 2012 Report Share Posted March 11, 2012 For the tach, try: http://www.tachman.com/ford.htm When the headlingts are on, the parking lights are off and work only in the turn signal mode as is standard for the era. Link to comment Share on other sites More sharing options...
twobjshelbys Posted March 11, 2012 Report Share Posted March 11, 2012 You should take this question to the SAAC forum: http://saac.com/index.php Lots more original car expertise there. Link to comment Share on other sites More sharing options...
Sudguy4 Posted March 11, 2012 Author Report Share Posted March 11, 2012 Thank you everyone for who has replied....will keep you posted with the restoration! Sudguy4 Link to comment Share on other sites More sharing options...
MY500SS Posted March 11, 2012 Report Share Posted March 11, 2012 Thank you everyone for who has replied....will keep you posted with the restoration! Sudguy4 Looking forward to seeing the progress. Link to comment Share on other sites More sharing options...
pchmotoho Posted October 12, 2012 Report Share Posted October 12, 2012 You should take this question to the SAAC forum: http://saac.com/index.php Lots more original car expertise there. Yea, what he said. You will find everything you need there (best automotive forum you will come across). Good luck with the red 350H Link to comment Share on other sites More sharing options...
Kevin Patten Posted October 13, 2012 Report Share Posted October 13, 2012 Check with MoMa Manufacturing in Albuquerque , New Mexico phone is (505) 766-6661 ask for Margaret . That's for the tach. As far as the turn signals go (fronts) they are a single filament bulb which are off when headlights are on ( I believe exported models were different due to European law) and the rear tail lights are a dual filament bulb are on with the lights - both are fed through the turn signal switch which has the power fed to the t/s switch from the head light switch . So a different or aftermarket turn signal switch may be what is causing the difference that you see from car to car. Getting too old to remember all this stuff. Link to comment Share on other sites More sharing options...
