slygray1 Posted March 7, 2012 Report Share Posted March 7, 2012 i am considering ordering the Gauge pod kit for my 2007 SGT/SC. Has anyone done the install themself? If so, any tips or advice. It looks like the fuel pressure connection could be a bear. Quote Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted March 8, 2012 Report Share Posted March 8, 2012 (edited) Couple folks have posted their install. Try a search in the modification section or maybe someone will post link. Edited March 8, 2012 by H0050 Quote Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted March 8, 2012 Report Share Posted March 8, 2012 (edited) I bought the pre-wired version and did the install myself and it was pretty easy - hardest part for me was wriggling under the dash and digging around for the proper wire(s) to connect! No problem with either the fuel pressure, oil pressure, and boost connections. The instructions are good and straight forward. Make sure you order the correct gauge pack and accessories, i.e., supercharged versus normally aspirated. See page two of this thread: http://www.teamshelb...__1#entry978832 Sam Edited March 8, 2012 by 2007_Shelby_GT Quote Link to comment Share on other sites More sharing options...
slygray1 Posted March 9, 2012 Author Report Share Posted March 9, 2012 (edited) Thanks Sam. I ordered the prewired SC kit along with the SC oil pressure adapter today. Did you have any problems with the fuel pressure adapter as far as clearance with the cold air intake tube? Or am I looking at the wrong picture? Edited March 9, 2012 by slygray1 Quote Link to comment Share on other sites More sharing options...
jwestercamp Posted March 9, 2012 Report Share Posted March 9, 2012 Talk to Jer he is. Good source on this Quote Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted March 10, 2012 Report Share Posted March 10, 2012 Thanks Sam. I ordered the prewired SC kit along with the SC oil pressure adapter today. Did you have any problems with the fuel pressure adapter as far as clearance with the cold air intake tube? Or am I looking at the wrong picture? No, no issues, but then again, I installed a Edelbrock E-force S/C - the Kenne Bell / Whipple install may be different! Sam Quote Link to comment Share on other sites More sharing options...
slygray1 Posted March 10, 2012 Author Report Share Posted March 10, 2012 I talked to Jer and he was world of help. There is a issue with the Whipple supercharger as far as clearance with the cai. It seems as though you either have to purchase an adapter from Whipple or change the fuel rails out for ones that have a port on the end for the fuel gauge sending unit to screw into. The adapter($180) is the easiest way to go but the fuel rails look the best($300+)from Shelby. Decision time. Quote Link to comment Share on other sites More sharing options...
SGT-C0056 Posted March 11, 2012 Report Share Posted March 11, 2012 I have installed the guage myself on two cars, very easy other than working under the dash upside down. Quote Link to comment Share on other sites More sharing options...
slygray1 Posted March 12, 2012 Author Report Share Posted March 12, 2012 (edited) I ordered the fuel gauge transducer adapter from Mike at Whipple. I will have a project when everything gets here. Edited March 12, 2012 by slygray1 Quote Link to comment Share on other sites More sharing options...
slygray1 Posted March 27, 2012 Author Report Share Posted March 27, 2012 I have everthing installed except for the oil gauge line from the filter housing to the oil manifold. For whatever reason I couldn't get the lines threads started into the filter housing. I may need to put the car on a lift so I can get at the right angle to start the threads. Anyone else have a problem with this? Quote Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted March 27, 2012 Report Share Posted March 27, 2012 I have everthing installed except for the oil gauge line from the filter housing to the oil manifold. For whatever reason I couldn't get the lines threads started into the filter housing. I may need to put the car on a lift so I can get at the right angle to start the threads. Anyone else have a problem with this? I did mine with jack stands without much difficulty, (except SAI forgot/doesn't supp/y the bolt to attach the manifold to the engine block!) - and yes, make sure you're at the proper angle or else you will cross-thread the line! Sam Quote Link to comment Share on other sites More sharing options...
slygray1 Posted April 3, 2012 Author Report Share Posted April 3, 2012 (edited) I put the car on a friends lift and had the oil line installed in less than 10 minutes. I to had to go and get some bolts to install the oil manifold to the block. Job is complete and all gauges work. Edited April 3, 2012 by slygray1 Quote Link to comment Share on other sites More sharing options...
SGT-C0056 Posted April 4, 2012 Report Share Posted April 4, 2012 I used my lift. I dont understand why they provide a kit WITHOUT a $0.25 Bolt!!! Quote Link to comment Share on other sites More sharing options...
