Don Johnston Posted February 28, 2012 Report Share Posted February 28, 2012 Any suggestions on modifying the driver sun visor so itt can swing past the guage pod? I am thinking of getting another one from Ford and cutting and gluing it to be narrow enough to able to use it. Comments... Quote Link to comment Share on other sites More sharing options...
SoCalSGT Posted March 3, 2012 Report Share Posted March 3, 2012 I hadn't realized it wouldn't. Keep us posted when you reach a solution. John Quote Link to comment Share on other sites More sharing options...
Don Johnston Posted March 3, 2012 Author Report Share Posted March 3, 2012 The factory was no help so I am planning on buying a new spare from the Ford dealer and measureing, cutting and gluing. A used one isn't too feasible as the model series is fairly new and it would have to come from a totalled GT. I will post the results of the effort. Quote Link to comment Share on other sites More sharing options...
Don Johnston Posted March 12, 2012 Author Report Share Posted March 12, 2012 Problem solved. It turned out the the crease at the corner of the visor was faulty (not fully scored). With some extra scoring with a butter knife and encouragement by gently rocking the edge back and forth, I got the visor to work as intended and it clears the gauge pod without problems. Quote Link to comment Share on other sites More sharing options...
Cali_KR Posted March 12, 2012 Report Share Posted March 12, 2012 Problem solved. It turned out the the crease at the corner of the visor was faulty (not fully scored). With some extra scoring with a butter knife and encouragement by gently rocking the edge back and forth, I got the visor to work as intended and it clears the gauge pod without problems. Hawaiian field engineering at its finest... Quote Link to comment Share on other sites More sharing options...
Don Johnston Posted March 12, 2012 Author Report Share Posted March 12, 2012 Getting a Ford approved butter knife was impossible. Not even Snap-On Tools had the correct item. So I had to raid the kitchen, then sneak it back. Hope the wife doesn't check this message. B) Quote Link to comment Share on other sites More sharing options...
