hilal Posted February 13, 2012 Report Share Posted February 13, 2012 Hi everyone Please help me in this if u can I just installed throtte body and supercharge elbo to my 07 GT500 after that I got filesafe engine mode error and the RPM is not moving from 900RPM even if I accelerate I really don't know what to do as I send justin an email and I'm still waiting for his replay..any one can help with advice? Quote Link to comment Share on other sites More sharing options...
09 Red GT500 Posted February 14, 2012 Report Share Posted February 14, 2012 Assuming you have a device to read the code such as SCT3, you can read the code and look it up on the internet. That may tell you what you need to look at next. Did you to make sure that have everything reconnected properly? Quote Link to comment Share on other sites More sharing options...
aonebadbone Posted February 14, 2012 Report Share Posted February 14, 2012 We need more details what kind of throttle body and elbow Quote Link to comment Share on other sites More sharing options...
hilal Posted February 14, 2012 Author Report Share Posted February 14, 2012 the elbow is (Silver GT500 High-Flow Inlet Elbow for TVS & Stock Blower +20-40HP) the throttle body is (65MM Cobra Jet Billet Aluminum GT500 Throttle Body) all from VMPtuning ..my car already run VMP tune from justin and he told me i dont need new tune for this parts as my car will adjust .when i first install it i started the car and the RPM shows 2500RPM and not coming down .then after some advice i disconnect the battery for 15 min then connect it then reload the tune then stared the car then the RPM shows normal 900RPM but its shows filesafe engine mode and the RPM not moving even is i accelerate .I connect my SCT and run the error cods its shows (P2104 and P2112) which is about throttle body and TPS ,i did check again nothing wrong its all connect and there is no air leak , then i clear the cods by SCT then disconnect the battery for 15 min then connect it and start the car it was same .. i toke off the throttle body and the elbow and install the stock one then the car run fine.technical gus says that the throttle body is stays close and not responding . any one can help with a dvice please i send justin email about it am sure he will replay ones he read it . thanks in advance Hilal Quote Link to comment Share on other sites More sharing options...
09 Red GT500 Posted February 15, 2012 Report Share Posted February 15, 2012 I'm sure Justin is very busy and doesn't always get to his emails. If you don't hear back from him, you should call him. His customer service is top notch. Quote Link to comment Share on other sites More sharing options...
Moncho Posted February 17, 2012 Report Share Posted February 17, 2012 OP have you ever gotten a response from VMP? Has the issue been resolved? Good Luck! Ray Quote Link to comment Share on other sites More sharing options...
hilal Posted February 18, 2012 Author Report Share Posted February 18, 2012 yes Justin has replay me and the problem will be solved soon ..Thanks to Justin and PJ from VMP. Quote Link to comment Share on other sites More sharing options...
hilal Posted February 25, 2012 Author Report Share Posted February 25, 2012 did anyone face same problem before? Quote Link to comment Share on other sites More sharing options...
clear front sight Posted February 28, 2012 Report Share Posted February 28, 2012 did anyone face same problem before? Yes, I did. My car would go into failsafe under hard acceleration and would throw the same codes, datalogged it and sent it to Justin. He adjusted the tune and it never hapened again. I think mine was the torque limit as a part of Ford's protection stategy, once I was over the torque limit, the car shut down the throttlebody and the computer went into failsafe . Quote Link to comment Share on other sites More sharing options...
