GT350conv Posted February 2, 2012 Report Share Posted February 2, 2012 http://www.1010tires.com/TireSizeCalculator.asp?action=submit Stumbled on this site earlier today when searching for replacement 20" Ford Explorer tires. Simply input your OEM tire size and select up to (4) alternate tire selections. Compares all the critical size and speed information you'll need. SVTPP rear tire is copied below but not sure why is says "Rim width range is unrecognizable" Tire Size Calculator - tire & wheel plus sizing Your Results: Start Over Stock Tire - 285/35R20 Search Tires Tire 1 - 285/40R20 Search Tires Tire 2 - 295/35R20 Search Tires Tire 3 - 305/35R20 Search Tires Tire 4 - 305/30R20 Search Tires Section Width: 11.22 in 285 mm Section Width: 11.22 in 285 mm Section Width: 11.61 in 295 mm Section Width: 12.00 in 305 mm Section Width: 12.00 in 305 mm Rim Diameter: 20 in 508 mm Rim Diameter: 20 in 508 mm Rim Diameter: 20 in 508 mm Rim Diameter: 20 in 508 mm Rim Width Range: Unrecognized tire size. Rim Width Range: Unrecognized tire size. Rim Width Range: Unrecognized tire size. Rim Width Range: Unrecognized tire size. Rim Width Range: Unrecognized tire size. Overall Diameter: 27.85 in 707.39 mm Overall Diameter: 28.97 in 735.83 mm Overall Diameter: 28.12 in 714.24 mm Overall Diameter: 28.40 in 721.36 mm Overall Diameter: 27.20 in 690.88 mm Sidewall Height: 3.92 in 99.568 mm Sidewall Height: 4.48 in 113.79 mm Sidewall Height: 4.06 in 103.12 mm Sidewall Height: 4.20 in 106.68 mm Sidewall Height: 3.60 in 91.44 mm Radius: 13.92 in 353.56 mm Radius: 14.48 in 367.79 mm Radius: 14.06 in 357.12 mm Radius: 14.20 in 360.68 mm Radius: 13.60 in 345.44 mm Circumference: 87.49 in 2222.2 mm Circumference: 91.01 in 2311.6 mm Circumference: 88.34 in 2243.8 mm Circumference: 89.22 in 2266.1 mm Circumference: 85.45 in 2170.4 mm Revs per Mile: 746.8 Revs per Mile: 717.9 Revs per Mile: 739.6 Revs per Mile: 732.3 Revs per Mile: 764.7 Actual Speed: 60 mph 100 km/h Speedometer1: 57.6 mph 96.1 km/h Speedometer1: 59.4 mph 99.0 km/h Speedometer1: 58.8 mph 98.0 km/h Speedometer1: 61.4 mph 102. km/h Speedometer Difference: - Speedometer Difference: 4.025% too slow Speedometer Difference: 0.973% too slow Speedometer Difference: 1.980% too slow Speedometer Difference: 2.396% too fast Diameter Difference: - Diameter Difference: 3.87% Diameter Difference: 0.97% Diameter Difference: 1.94% Diameter Difference: 2.34% Tire Models Available by Size: Bridgestone Blizzak LM-25 Run Flat Bridgestone Potenza RE050A Dunlop SP Sport 600 DSST CTT Pirelli P-Zero Pirelli Winter 240 Sottozero Serie II Pirelli Winter 270 Sottozero Serie II Toyo Proxes R888 Tire Models Available by Size: Nitto NT420S Tire Models Available by Size: Michelin Pilot Sport PS2 Michelin Pilot Super Sport Nitto Invo Pirelli P-Zero Tire Models Available by Size: Bridgestone Potenza RE050A Run Flat Michelin Pilot Sport PS2 Nitto NT555R Pirelli P-Zero Pirelli Winter 240 Sottozero Tire Models Available by Size: Pirelli P-Zero Link to comment Share on other sites More sharing options...
cwa2wa2011 Posted February 3, 2012 Report Share Posted February 3, 2012 Great Resource! Thanks for sharing! Link to comment Share on other sites More sharing options...
Larry T Posted February 3, 2012 Report Share Posted February 3, 2012 Here is another one http://www.rimsntires.com/specs.jsp?item=Wheel-Tire Link to comment Share on other sites More sharing options...
creilly333 Posted February 3, 2012 Report Share Posted February 3, 2012 So, when I compare these two calculators for the rear tires on my GT500 SVTPP they both give different results. The tire is 285/35 ZR20. According to one calculator the revs per mile is 724 and the other it's 746.8. What could I be doing wrong here? Colin Link to comment Share on other sites More sharing options...
GT350conv Posted February 3, 2012 Author Report Share Posted February 3, 2012 It appears that the rimsntire calculator rounds off for the calcuation. Example on the SVTPP 285/35/20 outside dia. is 27.9" = 723.9 revs/mile. The 1010tires calculator uses a more accuate number of 27.85" = 746.8 revs/mile. Link to comment Share on other sites More sharing options...
