rsfdiver Posted January 9, 2012 Report Share Posted January 9, 2012 Hi All, Dealer replaced mine with the RXT and before the 500 mile break in I noticed that some thing was hanging up the clutch petal on the way up near the fully depressed position. I thought it was the floor mat catching it some how. Now at 800 miles the hang up is more near the point of full engagement. Anyone know what would cause this? Link to comment Share on other sites More sharing options...
Moncho Posted January 24, 2012 Report Share Posted January 24, 2012 Wish I could help. Let us know what you find out. Good Luck, Ray Link to comment Share on other sites More sharing options...
VNMOUS1 Posted February 1, 2012 Report Share Posted February 1, 2012 Have them make absolutely sure the system is completely air free. Short of that, have them make sure they check the spacing specs. The RXT is a little touchy when it comes to set up. The plates need to be able to freewheel when you're setting them up. Been there...done that. bj Link to comment Share on other sites More sharing options...
rsfdiver Posted April 30, 2012 Author Report Share Posted April 30, 2012 Thanks for the replies and help fellas. It really feels like it is in the clutch pedal assembly, but ... Link to comment Share on other sites More sharing options...
bossnova3 Posted May 6, 2012 Report Share Posted May 6, 2012 This is the exact same symptom I'm having with mine, if you've gotten to the bottom of it please let us know Thanks Ed Link to comment Share on other sites More sharing options...
bossnova3 Posted May 8, 2012 Report Share Posted May 8, 2012 Just an update, called McLeod and talk to Lee he told me that according to my "symptoms" he thinks that it might be that the pressure plate not torqued down properly, do to the crush washer. Originally when the pressure plate was installed we hand tightened the bolts and then torqued them to 35ft/lbs he said that the proper way is to hit the bolts with and impact gun turned down in power so that the fingers of the pressure plate tightened down then torque them. Hopefully this would do the trick. Just an FYI my only symptom was a feeling of the clutch pedal catching almost at the fully depress position and at high rpm (5900 to 6000) it's really hard to get into 1-2 to 2-3 gear. Hopefully this would help someone in the future. Will do as advice and re update. Link to comment Share on other sites More sharing options...
rsfdiver Posted May 15, 2012 Author Report Share Posted May 15, 2012 Frustrating Anyone want to buy a gt500 with a clutch pedal hanging up? Cheap? Didn't think so. Link to comment Share on other sites More sharing options...
rsfdiver Posted May 17, 2012 Author Report Share Posted May 17, 2012 Cody at Stang Hi in Baton Rouge Link to comment Share on other sites More sharing options...
Grabber Posted May 17, 2012 Report Share Posted May 17, 2012 Cody at Stang Hi in Baton Rouge I am so glad to hear that this is going to get resolved. Let us know when the repair is copmplete and you are on the road again and happy. Sorry you have to go thru this. I feel for you. Link to comment Share on other sites More sharing options...
rsfdiver Posted May 18, 2012 Author Report Share Posted May 18, 2012 Thanks Grabber Link to comment Share on other sites More sharing options...
Snoopy49 Posted June 6, 2012 Report Share Posted June 6, 2012 Does your car have an over-center spring in the clutch pedal assembly? If so, it is there to help decrease clutch pedal effort. It may not be necessary with a diaphragm clutch? It may be holding the pedal down. Link to comment Share on other sites More sharing options...
