robertlane Posted December 12, 2011 Report Share Posted December 12, 2011 Shelby GT500 High Amp Alternator Shelby American's high performance GT500 alternators are 100% brand new and were designed to meet the rigorous demands for the need of increased amperage. We offer two different versions: • 80 Amp Idle / 160 Amp Max. • 100 Amp Idle / 200 Amp. Max. Applications: 2007-2009 Shelby GT500. Notes: The 100/200 Amp unit requires a new wiring harness pigtail, which is included. Release date: New product release: 12 December 2012. Made in the U.S.A. MORE HERE Link to comment Share on other sites More sharing options...
dbackg Posted December 13, 2011 Report Share Posted December 13, 2011 Very cool. What's the difference vs. Ford OEM stock alternator? Link to comment Share on other sites More sharing options...
cobrafan Posted December 13, 2011 Report Share Posted December 13, 2011 This is a screaming deal. Mine went out as well as Msmap in Houston and it was considerably more expensive than this for an OEM that you cannot get new, reconditioned only. Link to comment Share on other sites More sharing options...
DubbsFaris Posted December 13, 2011 Report Share Posted December 13, 2011 yup, mine went out on my gt500 as well...a much needed upgrade! Link to comment Share on other sites More sharing options...
05mustangman Posted December 13, 2011 Report Share Posted December 13, 2011 Will one be offered for the 2010+? Link to comment Share on other sites More sharing options...
Larry T Posted December 13, 2011 Report Share Posted December 13, 2011 Awesome ..... keep them coming!!!!! Link to comment Share on other sites More sharing options...
Sherri Leicht Posted December 13, 2011 Report Share Posted December 13, 2011 Awesome!! Link to comment Share on other sites More sharing options...
richard m.switzer Posted December 13, 2011 Report Share Posted December 13, 2011 Will this work on a 2006-2008 Shelby GT or GT-H ?,4.6 motor ,,or is their any plans to have one make by Shelby Parts . Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted December 13, 2011 Report Share Posted December 13, 2011 This is a screaming deal. Mine went out as well as Msmap in Houston and it was considerably more expensive than this for an OEM that you cannot get new, reconditioned only. Actually, in most cases where the factory is selling "reconditioned" parts, they're brand new. And not just on electronic parts. I've seen water pumps sold as "reconditioned" that were brand new parts (and ECM's/PCU's, and, alternators, and, and, and......). They sell them as reconditioned so they can charge you a core charge. That encourges you to return the old unit to *them*. They want the old units so they can keep them out of the hands of rebuilders, who will rebuild them and create a market for less expensive units (driving the prices of new units down). It's a ploy to keep the price of new parts, up. And it works for the first few years (and many times, well beyond). Phill Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted December 13, 2011 Report Share Posted December 13, 2011 What's the difference vs. Ford OEM stock alternator? I had just about the same question: What is the stock alternator amperage output rating? Phill Link to comment Share on other sites More sharing options...
JonathanE Posted December 14, 2011 Report Share Posted December 14, 2011 The stock alternator is 110 amps Link to comment Share on other sites More sharing options...
tedj Posted December 14, 2011 Report Share Posted December 14, 2011 Why is the stock unit not enough? Are failures due to additional load like large stereo amps? Link to comment Share on other sites More sharing options...
robertlane Posted December 14, 2011 Author Report Share Posted December 14, 2011 Will this work on a 2006-2008 Shelby GT or GT-H ?,4.6 motor ,,or is their any plans to have one make by Shelby Parts . Will not work on a 4.6L. Yes, we are going to make them avail. to those engines too. The stock alternator is 110 amps Correct. Why is the stock unit not enough? Are failures due to additional load like large stereo amps? Larger stereos, electric fans, bigger i.c. cooler pumps. . . Link to comment Share on other sites More sharing options...
03 DSG Snake Posted December 14, 2011 Report Share Posted December 14, 2011 Why is the stock unit not enough? Are failures due to additional load like large stereo amps? Plenty failed on stock or near stock setups. 2003/2004 Cobras are still having alternator issues. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted December 14, 2011 Report Share Posted December 14, 2011 Why is the stock unit not enough? Are failures due to additional load like large stereo amps? It's not that they will *fail* from additional load, it's that they can't keep up with the additional demand and your battery will not get charged sufficiently. Once a car starts, the Alternator is what powers all the accessories and recharges the battery (which drains from parisitic loads and starter useage). The *battery* only needs to be a large enough capacity to crank the engine over and power the ROM and other memory chips in the car (Radio, clock, etc.). To calculate your Alternator rating you turn on ALL power accessories and note the Amperage draw. Add the Starter draw to that number then add 15% to give you some leeway. If you put a big bumpin' stereo on a car and crank it up, you will see your headlamps dim with each "thump". That is a sign your alternator is insufficent....AND, you need to add a big capaciter to stop the voltage pulses created by the stereo demand. A larger rated Alternator is a MUST if you run a lot of, or a single LARGE draw electrical/electronic device, such as a stereo/amp, larger/more cooling fans, large cap IC pump, etc. etc. etc. The more you use, the more you need (i.e. "supply/demand"). If your car is stock or close to it, you'll gain nothing by adding a lager capacity Alternator. You can have a 500Ma Alternator (no such thing, just sayin') buf if all you use is 80a MAX, it's wasted. Phill Link to comment Share on other sites More sharing options...
richard m.switzer Posted December 14, 2011 Report Share Posted December 14, 2011 Will not work on a 4.6L. Yes, we are going to make them avail. to those engines too. Correct. Larger stereos, electric fans, bigger i.c. cooler pumps. . . ,,Thanks ,, :happy feet: :happy feet: :happy feet: Link to comment Share on other sites More sharing options...
Ackman70 Posted December 14, 2011 Report Share Posted December 14, 2011 Robert, I see this is listed for '07-'09 model years. I just went through this with PA Performance, another aftermarket alternator/starter supplier, that the '07-'08 alternators are different then the '09 and they are not interchangeable. '07-'08 use a Ford alternator and the '09 use a Nippondenso unit. If one tries to use an earlier Ford in an '09 the battery light on the dash will stay on. Does any of this hold true for your unit? Link to comment Share on other sites More sharing options...
dbackg Posted December 15, 2011 Report Share Posted December 15, 2011 Robert, I see this is listed for '07-'09 model years. I just went through this with PA Performance, another aftermarket alternator/starter supplier, that the '07-'08 alternators are different then the '09 and they are not interchangeable. '07-'08 use a Ford alternator and the '09 use a Nippondenso unit. If one tries to use an earlier Ford in an '09 the battery light on the dash will stay on. Does any of this hold true for your unit? Good post. Link to comment Share on other sites More sharing options...
Ackman70 Posted December 18, 2011 Report Share Posted December 18, 2011 Good post. Their silence confirms it. Plus I see they updated the desciption in the Shelby Store. Link to comment Share on other sites More sharing options...
JonathanE Posted December 21, 2011 Report Share Posted December 21, 2011 Their silence confirms it. Plus I see they updated the desciption in the Shelby Store. Sorry about the error on this. Yes the application is for 2007-2008 GT500 and has been updated on the store. Thanks for letting us know. Link to comment Share on other sites More sharing options...
RayMan Posted December 24, 2011 Report Share Posted December 24, 2011 Where can we get a chromed unit for the '09's? Link to comment Share on other sites More sharing options...
robertlane Posted December 24, 2011 Author Report Share Posted December 24, 2011 We probably won't make a chrome unit to the heat it builds up. Link to comment Share on other sites More sharing options...
ragtopfever Posted January 8, 2012 Report Share Posted January 8, 2012 I just got the 200amp alternator and the installation was going well until I realized the upgraded 48" power cable is way too short. My understanding is the new power wire should run along side the original wire back to the battery, but it's about 18 inches too short. So much for the drive I had planned on this beautiful California afternoon Any suggestions short of calling SA tomorrow? Link to comment Share on other sites More sharing options...
ragtopfever Posted January 10, 2012 Report Share Posted January 10, 2012 Made some calls and it turns out the new power cable is meant to run to the fuse block, not to the battery. Just waiting for the weekend so I can git 'er done. Link to comment Share on other sites More sharing options...
me32 Posted January 13, 2012 Report Share Posted January 13, 2012 i am im my 3rd stock Alt now. within 3 years ive had 2 fail. so im getting tired of this. these new alts how many RPMs are they good for? Link to comment Share on other sites More sharing options...
dbackg Posted January 14, 2012 Report Share Posted January 14, 2012 i am im my 3rd stock Alt now. within 3 years ive had 2 fail. so im getting tired of this. these need alts how many RPMs are they good for? Great question. Are you running the stock under pulley damper? Link to comment Share on other sites More sharing options...
me32 Posted January 14, 2012 Report Share Posted January 14, 2012 Great question. Are you running the stock under pulley damper? i run the stock 2008 Lower pulley damper, with a FRPP TVS 2.3 an VMP 2.59 pulley an VMP idler pulley. with a stock belt. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted January 14, 2012 Report Share Posted January 14, 2012 Where can we get a chromed unit for the '09's? You don't want a Chrome alternator. See Robert's reply for the "why not". Take it apart and have the body polished. That'll last, won't peel and won't retain heat like Chrome will. Any good polishing shop can do it or if you have TONS of patience, you can do it. Phill Link to comment Share on other sites More sharing options...
me32 Posted January 19, 2012 Report Share Posted January 19, 2012 any info yet on how many RPMs this can handle? Link to comment Share on other sites More sharing options...
me32 Posted January 24, 2012 Report Share Posted January 24, 2012 ok so my question is can this Alt run At 7000RPMs on the engine like the 2013 GT500 which has a red line of 7000RPM. Link to comment Share on other sites More sharing options...
