Staff Posted November 15, 2011 Report Share Posted November 15, 2011 2013 Shelby GT500 Introduction 2013 Ford Shelby GT500 Debuts As Most Powerful Production V8 in the World with 650 Horsepower, Top Speed of 200+ MPH • New Ford Shelby GT500 is powered by an aluminum 5.8-liter supercharged V8 producing 650 horsepower and 600 lb.-ft. of torque, making it the most powerful production V8 engine in the world • Nearly every vehicle system has been optimized including powertrain, brakes, gearing and suspension • New Shelby GT500 sets a performance-driven design standard with new downforce- generating front grilles, aggressive splitter, new quad exhaust system and two new forged-aluminum wheels • Also new for 2013 is an optional Performance Package with SVT-designed Bilstein electronic adjustable dampers and a Torsen limited-slip differential. The offering can be coupled with a track package for all-out racetrack performance. Team Shelby – The ultimate Ford Mustang – Shelby GT500 – raises the bar high on performance with the introduction of the new 2013 model that goes on sale next year delivering 650 horsepower and a top speed of more than 200 mph. “SVT keeps the Shelby GT500 on the cutting edge of technology and takes muscle car performance to new heights,” said Jost Capito, director of Global Performance Vehicles and Motorsport Business Development. “We encapsulated every aspect of performance in this car – whether it’s 0-60, top speed, racetrack or quarter-mile times. Beyond that, the daily driver also will find this car perfectly fits his or her needs.” The 5.8-liter V8 aluminum-block engine produces 650 horsepower and 600 lb.-ft. of torque, making it the most powerful production V8 in the world. The 3,850-pound car also stays exempt from the gas-guzzler tax. Nearly every part of the powertrain has been optimized for producing the additional horsepower, including a new supercharger, new cross-drilled block and heads, updated camshaft profiles, a new carbon fiber driveshaft and upgraded clutch, transmission and axle. A larger, more-efficient supercharger flowing more air through the engine is key to helping produce the massive 650 horsepower. The new TVS series 2300 creates 2.3 liters of displacement and is a unique design to the 5.8-liter engine. The entire cooling system has been significantly updated on the new 5.8-liter engine. It now includes a larger cooling fan, fan shroud with high-speed pressure-relief doors, a more efficient charge air cooler, a higher-flow intercooler pump and an intercooler heat exchanger with volume increased 36 percent. Revised gearing Nearly every gear on the 2013 Ford Shelby GT500 was revised to manage the torque and use more of the power in a way that makes it more driver-friendly. Engineers considered more than 35 gearing combinations, finally deciding on one that delivers less torque all the way through the wheels to the ground and still enables the car to achieve fuel economy targets. A key piece of the driveline, the six-speed manual transmission, offers upgraded gears, bearings and housing so it can properly manage the torque. The final drive ratio is now 3.31:1 for optimized overall vehicle gearing to complement the massive torque. Every gear besides fourth was optimized for competing performance metrics. The clutch has increased torque and rpm capacity and uses a dual-disc design. “It might just seem like we’re putting a bigger engine into the car. But it’s been a balanced approach through and through,” said Jamal Hameedi, SVT chief engineer. “We’ve completely redone the car to be even more sophisticated in terms of handling and control than the prior model.” Other keys for improved traction management include: • Torsen limited-slip differential:When customers order the optional Performance Package, they will get a Torsen limited-slip differential that helps the rear suspension deliver maximum torque and traction better and longer under track conditions • Launch control: A new launch control system lets drivers set the desired launch rpm depending on tire temperature, street surface or other conditions. Unique to SVT’s launch control is that it is integrated with both the engine control and traction control • Brembo braking system: A new Brembo brake system offers drivers enhanced stopping power to help keep their car under control, both on the road and the track. New six-piston calipers in front along with larger front and rear rotors help improve brake fade. New brake pads that are more aggressive also help the car achieve high deceleration and further robustness for more driver confidence Aero advancements Significant aerodynamic work was done on the new Shelby GT500 to ensure the car has proper downforce for optimum performance at all speeds. Engineers were able to determine how to harness the air that was moving around and through the car to improve the cooling system, maximize downforce and minimize drag. The front fascia and splitters were modified to handle the extreme loads at 200 mph, resulting in a car that tracks more securely and feels more planted to the road at higher speeds. It offers 33 percent more effective aero loading at 160 mph compared to the 2011 model. Superior ride The new Shelby GT500’s driving dynamics have been improved, now working in concert with all the new content on the car. Handling, all AdvanceTrac settings and steering assist levels within selectable steering have been tuned to account for the updated content. The previously available unique traction control system and electronic stability control settings help drivers achieve maximum performance on both the street and the track. Both systems can be completely disabled in controlled track situations where maximum driver skill is utilized, or fully engaged for maximum safety during normal driving or in less-than-ideal traction conditions. Intermediate sport mode allows drivers to push their cars hard at the track without completely disabling the safety systems, permitting more aggressive driving before the traction control and electronic stability control intervene. “We took a completely different approach with this car so drivers can choose their settings instead of a computer making the selection,” Hameedi said. “Nearly every system the driver interacts with can be tailored to his or her situation including the Bilstein electronic adjustable suspension, launch control, AdvanceTrac and steering assist levels.” The 2013 Shelby GT500 offers two new sets of forged-aluminum wheels including a unique wheel for cars with the optional packages. The 19-inch front and 20-inch rear wheels are coupled with Goodyear Eagle® F1 SuperCar G: 2 tires on all vehicle configurations. Taking it one step further Sometimes Ford Shelby GT500 customers want to enjoy their car on surface streets. Other times they just want to let loose on the track. Two new optional packages on the 2013 model give them the choice. Available as part of the optional Performance Package, SVT-designed Bilstein electronic adjustable dampers are accessed on the dash with a simple push of a button. Normal mode gives customers a more comfortable ride over road irregularities. Sport mode is all about performance, delivering improved response time on the track and less body roll while cornering and pitch under braking. The Torsen limited-slip differential also comes with the Performance Package. “The adjustable shocks let us develop our car on the track without any compromise,” said Kerry Baldori, Ford SVT Global Performance Vehicles chief engineer. “Before, we had to tune the car with street implications in mind. Now we can go as extreme as we want on the track setting and still offer the customer a comfortable ride on the road.” Enthusiasts can upgrade their Performance Package with an additional Track Package for all-out performance. The option comes with an external engine oil cooler, rear differential cooler and transmission cooler for further durability. The coolers play an essential role in preventing crucial components from overheating under high-speed conditions. The 2013 Ford Shelby GT500 will be built at AutoAlliance International Plant in Flat Rock, Mich. Quote Link to comment Share on other sites More sharing options...
Aussie67 Posted November 15, 2011 Report Share Posted November 15, 2011 Wow :happy feet: Wow Wow I want one so bad.............. Quote Link to comment Share on other sites More sharing options...
twobjshelbys Posted November 15, 2011 Report Share Posted November 15, 2011 No mention of the 6-speed automatic? Quote Link to comment Share on other sites More sharing options...
snblaw Posted November 15, 2011 Report Share Posted November 15, 2011 No mention of price either.... Quote Link to comment Share on other sites More sharing options...
twobjshelbys Posted November 15, 2011 Report Share Posted November 15, 2011 Looks like the automatic is in the GT only, not the GT500. Too bad, I wouldn't mind a paddle-shift auto... Quote Link to comment Share on other sites More sharing options...
svtkeith Posted November 15, 2011 Report Share Posted November 15, 2011 Wow is right...If they don't price it out of this world I'll be trading the Z06 on one for sure... :happy feet: Quote Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted November 15, 2011 Report Share Posted November 15, 2011 Badass! Quote Link to comment Share on other sites More sharing options...
dbowles22 Posted November 15, 2011 Report Share Posted November 15, 2011 Ford really stepped up to the plate on this one. Not comparing the two, but this car has a better power to weight ratio then the Z06. Bravo Ford. I wonder if they added the comfort package to the GT500 option list? I'd say fully spec'd out it'll top out around $65K Quote Link to comment Share on other sites More sharing options...
REVENGE Posted November 15, 2011 Report Share Posted November 15, 2011 (edited) Wow amazing! My jaw is on the floor. This is the GT500 to get. All those people who thought the muscle car was dead in 2008 were so wrong. I will look forward to reading the opinions of the 07-09 owners on the styling and performance of this monster. Edited November 15, 2011 by REVENGE Quote Link to comment Share on other sites More sharing options...
creilly333 Posted November 15, 2011 Report Share Posted November 15, 2011 (edited) Wow amazing! My jaw is on the floor. This is the GT500 to get. All those people who thought the muscle car was dead in 2008 were so wrong. I will look forward to reading the opinions of the 07-09 owners on the styling and performance of this monster. This car will be amazing, however I just recently purchased a 2012 SVTPP and as much as I'd like one of these it really is out of the question for me. There's no way I could afford to purchase a new model every time one is released and we haven't yet seen what they are going to bring to the table in 2014. There is a little buyers remorse for sure but I still have a great car, and that's the thing, it doesn't make it any less of a great car just because of the new one. Good luck to all who are in a position to buy one! Colin Edited November 15, 2011 by creilly333 Quote Link to comment Share on other sites More sharing options...
bpmurr Posted November 15, 2011 Report Share Posted November 15, 2011 This car will be amazing, however I just recently purchased a 2012 SVTPP and as much as I'd like one of these it really is out of the question for me. There's no way I could afford to purchase a new model every time one is released and we haven't yet seen what they are going to bring to the table in 2014. There is a little buyers remorse for sure but I still have a great car, and that's the thing, it doesn't make it any less of a great car just because of the new one. Good luck to all who are in a position to buy one! Colin 2014 will be the same car with 2015 being an all new Mustang but probably just a GT and standard model the first year. Quote Link to comment Share on other sites More sharing options...
Roush GR40 Posted November 15, 2011 Report Share Posted November 15, 2011 Not sure if this is confirmed, but one release mentioned a 25% price increase over 2012....putting the 2012 in the $60,000 - $65,000 range. Quote Link to comment Share on other sites More sharing options...
davidbdzuris Posted November 15, 2011 Report Share Posted November 15, 2011 Thats it! My GT-H at 325 HP will have to go! Time for more HP! Quote Link to comment Share on other sites More sharing options...
bpmurr Posted November 15, 2011 Report Share Posted November 15, 2011 Not sure if this is confirmed, but one release mentioned a 25% price increase over 2012....putting the 2012 in the $60,000 - $65,000 range. Ouch, lets hope that is incorrect. Ford opens the door back up for the ZL1 at that price point. Quote Link to comment Share on other sites More sharing options...
svtkeith Posted November 15, 2011 Report Share Posted November 15, 2011 Not sure if this is confirmed, but one release mentioned a 25% price increase over 2012....putting the 2012 in the $60,000 - $65,000 range. Thats in the US....Here in Canada would be more like $70 - $75,000 area...A 2012 SVTPP is $63,000 here right now so yeah I'm thinking up here it's going to be closer to $75,000-$80,000 for a fully decked out one. Quote Link to comment Share on other sites More sharing options...
Dubstang Posted November 15, 2011 Report Share Posted November 15, 2011 I love it. Although I really am still partial to the '07-'09 style, who could turn their nose up to this latest version by Ford. Problem for me now is I will never sell my '08 with everything I have put into it. It is a classic to me and I will have it forever. However, I want one of these new '13 Mustangs. But which one? The GT500 is clearly going to be incredible, but I already have one that makes 650 to the crank with the stock blower. Eventually it will sit more than it does now so I think I would opt for the '13 Boss. I like the new stripe design and wheels to go with the paint job. It actually looks liveable now. That to me would be the best track car option while keeping my GT500 for cruising around and having fun. The new GT500 will undoubtedly be impressive for any driving condition, but I fear that the cost is going to be insane while the Boss will be more reasonable. Sure is nice to have choices like these! I mean come on. Almost too good to be true. I will say that the rearend of the '13 GT500 (my only complaint for the '10-'12's) is looking pretty damn good with those four exhaust tips. I have gone back and forth on buying a GT350 or a '12 GT500 SVTPP. Sure am glad I waited. The '13 and '14 GT500 and Boss are going to be the tops of the S197 platform. Leaps and bounds ahead of anything they have produced to date. If I owned a '12 GT500, I would be beside myself right now, depending on the price of '13 of course. Jim Quote Link to comment Share on other sites More sharing options...
Cali_KR Posted November 15, 2011 Report Share Posted November 15, 2011 MUST HAVE......MUST HAVE....... Quote Link to comment Share on other sites More sharing options...
creilly333 Posted November 15, 2011 Report Share Posted November 15, 2011 2014 will be the same car with 2015 being an all new Mustang but probably just a GT and standard model the first year. Yeah, I meant the 2015, whenever the all new Mustang is coming out. I've been thinking and had a change of heart. I just bought my 2012 a couple months ago and done nothing to it so far, in fact it still only has about 600 miles on it, and like others are kicking themselves right now. This car is just too good to pass up, with a lot of very nice improvements, so I've contacted my dealer to express interest and get on a list if they have one. Jeez, what am I thinking? Quote Link to comment Share on other sites More sharing options...
Dubstang Posted November 15, 2011 Report Share Posted November 15, 2011 Yeah, I meant the 2015, whenever the all new Mustang is coming out. I've been thinking and had a change of heart. I just bought my 2012 a couple months ago and done nothing to it so far, in fact it still only has about 600 miles on it, and like others are kicking themselves right now. This car is just too good to pass up, with a lot of very nice improvements, so I've contacted my dealer to express interest and get on a list if they have one. Jeez, what am I thinking? It's only money (easy to say if you have it) and you only live once. Eat the cost and get the car you want. It appears that the '13 is going to be tops of this platform. Who knows what '15 will hold if a GT500 at all. The '13 and '14 are going to be the sh@t!!! Quote Link to comment Share on other sites More sharing options...
Dubstang Posted November 15, 2011 Report Share Posted November 15, 2011 Sorry if people have already seen this. Latest info I have come across on the ZL1. Pretty impressive and a good price. http://www.camaro5.com/2012-camaro-zl1-price-announced-at-54095 Quote Link to comment Share on other sites More sharing options...
bigsnake Posted November 15, 2011 Report Share Posted November 15, 2011 Two questions, what are the color options and when do the order banks open ? Quote Link to comment Share on other sites More sharing options...
mach 1 1970 Posted November 15, 2011 Report Share Posted November 15, 2011 (edited) Sorry if people have already seen this. Latest info I have come across on the ZL1. Pretty impressive and a good price. http://www.camaro5.com/2012-camaro-zl1-price-announced-at-54095 Wow $54k for all that technology hope they keep the GT500 close. This competition is just out of this world. Now it looks like the Gt500 will be able to put down it's power all 650 . Edited November 15, 2011 by mach 1 1970 Quote Link to comment Share on other sites More sharing options...
Dubstang Posted November 15, 2011 Report Share Posted November 15, 2011 Some of the comments on the Camaro Forum are priceless! They are seriously freaked out by the '13 GT500. Here is one example: "HATE TO SAY IT BUUUUUUTTTTTTTTTTTTTTTTTTTT THIS car is gonna get handled by that new 2013 GT500. Just saying. and im a big chevy fan but this stang is looking pretty sinister" Gotta love it. Nice work SVT! Quote Link to comment Share on other sites More sharing options...
Fletch60 Posted November 15, 2011 Report Share Posted November 15, 2011 I had a 2009 GT500 and now have a 2012. There is a HUGE difference between the two cars. It sounds like the 2013 will bring another big improvement. Nice job Ford management and engineers. Keep up the good work! I don't understand - cant believe that Ford, with as many technological advances as they have made, can't - doesn't offer an automatic. I know it's going to be a tad bit heavier but hey, it's already at 3850 or so now. Woopity doo. Give us an option for a 6-speed automatic! Maybe with a paddle shift. As for the ZL1 Camaro I think it's nice and priced well AND has an optional automatic [dodging bullets from the hard core oval guys :>) ] Now if I had the dough, I'd go with the GT. Maybe when I win that lottery :>) Hey Kev, give Cody a call and tell him we're bringing our 2012's in to trade! lol. Quote Link to comment Share on other sites More sharing options...
Boss Hoss 540 Posted November 15, 2011 Report Share Posted November 15, 2011 (edited) Anybody want a 7 month old loaded 2012 Black Lead Sled -- I Mean GT500??????? It is too much HP for me yeah thats it too much for me to handle and I need a 2013 with the better suspension yeah that it!!! Edited November 15, 2011 by Boss Hoss 540 Quote Link to comment Share on other sites More sharing options...
LuckySnake Posted November 15, 2011 Report Share Posted November 15, 2011 (edited) Will it be a limited edition? Edit: just funnin Edited November 15, 2011 by LuckySnake Quote Link to comment Share on other sites More sharing options...
SGT-C0056 Posted November 15, 2011 Report Share Posted November 15, 2011 2007 - 2012 GT500's just took a price depresiation Quote Link to comment Share on other sites More sharing options...
Shelbyville Posted November 16, 2011 Report Share Posted November 16, 2011 Glad to see the wide stripes - those narrow ones just didn't look right. Quote Link to comment Share on other sites More sharing options...
mullens Posted November 16, 2011 Report Share Posted November 16, 2011 They mentioned a new supercharger...is that a TVS? Quote Link to comment Share on other sites More sharing options...
supersnake94 Posted November 16, 2011 Report Share Posted November 16, 2011 They mentioned a new supercharger...is that a TVS? Quote Link to comment Share on other sites More sharing options...
