Moncho Posted November 3, 2011 Report Share Posted November 3, 2011 Seems as though when replacing the LCA you should replace the bolts & nuts that support the LCA's. Can someone confirm? If so, are there suitable replacements as the dealership wants quite a bit for them. Or do the replacement LCA's include them? Cheers, Moncho Quote Link to comment Share on other sites More sharing options...
Grabber Posted November 3, 2011 Report Share Posted November 3, 2011 I know that not all will agree with me.....but....many did as I did and used the same bolts and did not replace them. Quote Link to comment Share on other sites More sharing options...
KLG Posted November 3, 2011 Report Share Posted November 3, 2011 When I was shopping for replacement LCAs, I do not recall that new mounting hardware was supplied by any of the manufacturers that I considered. I eventually purchased Steeda's billet aluminum LCAs and for sure these did not include new hardware. As far as should the hardware be replaced, Ford suggests this hardware is to be used only once. From what I have read on this site, some individuals use new mounting hardware and others do not. I have not heard of anyone who has had a problem as a result of re-using the mounting hardware. Regardless, I did use new hardware when I replaced my LCAs. --KLG-- Quote Link to comment Share on other sites More sharing options...
54First Posted November 3, 2011 Report Share Posted November 3, 2011 (edited) I don't know for sure what Ford's reasoning is, but I do know something about the fasteners. They're all flange head bolts and flange head/nylok nuts. The flanges have a curve to them that applies tension when tightened. After being tightened then loosened the curve is deformed. No more tension. Also, Nylok nuts are good for one use. The nylon doesn't grip as well after use. Therefore, the torque may not be maintained. Solution: plenty of blue Loctite on the metal threads, not on the nylon part. Steve. Edited November 3, 2011 by 54First Quote Link to comment Share on other sites More sharing options...
Moncho Posted November 3, 2011 Author Report Share Posted November 3, 2011 Thank you all for your responses, got some great information. Now I can make an informed decision on which way to go on this. Looks like it will be a compromise of using the bolts & replacing the nuts. Excellent information! Cheers, Moncho Quote Link to comment Share on other sites More sharing options...
54First Posted November 4, 2011 Report Share Posted November 4, 2011 replacing the nuts. Cheers, Moncho Hey Moncho, A Nylock nut has both metal and nylon parts. If you use blue Loctite in the metal part of the nut you can reuse the nut also. I've done it many times. Steve Quote Link to comment Share on other sites More sharing options...
Moncho Posted November 5, 2011 Author Report Share Posted November 5, 2011 Hey Moncho, A Nylock nut has both metal and nylon parts. If you use blue Loctite in the metal part of the nut you can reuse the nut also. I've done it many times. Steve Steve, I'll go your route and use th blue Loctite, can't argue with success. Thanks for for taking the time to respond! Cheers, Moncho Quote Link to comment Share on other sites More sharing options...
shelbypt Posted December 6, 2011 Report Share Posted December 6, 2011 Great information here. I will keep this in mind for the LCA upgrade. Quote Link to comment Share on other sites More sharing options...
