zachman Posted September 30, 2011 Report Share Posted September 30, 2011 Checked my sight glass on my supercharger and it was empty, (no visible leaks). This is the second time in 8 months. Called Michael at Whipple and he said it happens in one in a thousand. You would know it; "I have the one"! Anyone else have this problem? Had the install at SAI in October of 2009. Approx. 1900 miles on supercharger. Link to comment Share on other sites More sharing options...
William Rodgers Posted September 30, 2011 Report Share Posted September 30, 2011 Interesting, I never checked mine I am going to check when I get home I am assuming I am fine because it works perfect Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted September 30, 2011 Report Share Posted September 30, 2011 Porosity in the case maybe? Link to comment Share on other sites More sharing options...
zachman Posted September 30, 2011 Author Report Share Posted September 30, 2011 Interesting, I never checked mine I am going to check when I get home I am assuming I am fine because it works perfect I don't drive my car that often; so I always check the fluids and tires before blasting off. Everything was working good. Kept noticing fluid in sight glass on supercharger was going down. Might have to buy a YUGO! Link to comment Share on other sites More sharing options...
arants Posted October 1, 2011 Report Share Posted October 1, 2011 Not an "official" SC, the install was done before I acquired the car, but it's still a hoot!--if Only SAI would make provisions for doing a modification check--then I'd be set, but I digress... I haven't noticed any issues through the sight gauge with about 2400 miles on the Supercharger. Sorry to hear that anyone is having issues, hopefully the one in a thousand holds true, still I hope for a quick resolution for you, and that it's minor if nothing else!! Link to comment Share on other sites More sharing options...
SWEDEMAN Posted October 1, 2011 Report Share Posted October 1, 2011 Call Roger @ SA, he told me SA stands behind it work, I don't know how long that "hand-shake" warranty would last but I am sure he'd help you out if possible. Link to comment Share on other sites More sharing options...
zachman Posted October 1, 2011 Author Report Share Posted October 1, 2011 Call Roger @ SA, he told me SA stands behind it work, I don't know how long that "hand-shake" warranty would last but I am sure he'd help you out if possible. Talked to Michael at Whipple, Friday. I have to send the supercharger to Whipple in, Califorina. Never had any luck talking to Roger. Always someone else's problem. Link to comment Share on other sites More sharing options...
NordicShelby Posted October 2, 2011 Report Share Posted October 2, 2011 Call Roger @ SA, he told me SA stands behind it work, I don't know how long that "hand-shake" warranty would last but I am sure he'd help you out if possible. THERE IS NO WARRANTY from Shelby on a Whipple 550 install that is why some people had chosen to get it done at the FORD dealer where there is a warranty. Whipple is very good and I am sure they will take care of you. Michael always bends over backwards when I have called him with a question. Link to comment Share on other sites More sharing options...
RogerS Posted October 2, 2011 Report Share Posted October 2, 2011 Talked to Michael at Whipple, Friday. I have to send the supercharger to Whipple in, Califorina. Never had any luck talking to Roger. Always someone else's problem. Really! If don't remember recieving your call on this issue. We we do our best to assist everyone with their issues. Shelby related or not and have a dedicated customer service and technical rep ready to assist. Your Ford Racing Whipple Supercharger carries a 12/12 warranty from Ford Racing. Shelby also honors that warranty on Ford racing parts and 12 months from in service date on all installations and defective parts and workmanship. Looking at your in service date we would have also contacted Michael at Whipple for possible causes and resolution. Rogers@shelbyamerican.com or 702-942-7325 ext. 145. I am available after 7 AM. Roger Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted October 2, 2011 Report Share Posted October 2, 2011 When the problem gets solved, could you please post what the problem was that was causing the oil leak? Thanks. Link to comment Share on other sites More sharing options...
NordicShelby Posted October 2, 2011 Report Share Posted October 2, 2011 Back in April 2009 I was told that there is NO warranty on Whipple 550 installs. So if I blew the engine up I would be SOL. Just curious to when Shelby American started offering warranty on Whipple 550 installs? Link to comment Share on other sites More sharing options...
jmn444 Posted October 2, 2011 Report Share Posted October 2, 2011 The warranty is on the blower not the engine. Link to comment Share on other sites More sharing options...
jmn444 Posted October 2, 2011 Report Share Posted October 2, 2011 Thats my assumption anyway. I think most speed shops would do the same unless it was the engine they built, and even then, not sure. Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted October 3, 2011 Report Share Posted October 3, 2011 If Shelby installed for you, they will stand behind the workmanship and assist as needed. I am talking from experience. I suggest you call Roger Sorel. An email also works. Would suggest not use the forum to contact SAI. The staff does check the site and replies but issues are better resolved with direct contact. Good luck Link to comment Share on other sites More sharing options...
zachman Posted October 4, 2011 Author Report Share Posted October 4, 2011 If Shelby installed for you, they will stand behind the workmanship and assist as needed. I am talking from experience. I suggest you call Roger Sorel. An email also works. Would suggest not use the forum to contact SAI. The staff does check the site and replies but issues are better resolved with direct contact. Good luck I removed the supercharger today and sent it to Whipple; in Fresno, Calif.. Michael said they would take a look at it. Will keep everyone posted. I would also like to clarify the fact that I didn't expect SAI to be responsible for my problem. Just inquiring if anyone else had this problem. Thanks. Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted October 4, 2011 Report Share Posted October 4, 2011 THERE IS NO WARRANTY from Shelby on a Whipple 550 install that is why some people had chosen to get it done at the FORD dealer where there is a warranty. Whipple is very good and I am sure they will take care of you. Michael always bends over backwards when I have called him with a question. ;@) should really have listened to me though huh? Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted October 4, 2011 Report Share Posted October 4, 2011 If Shelby installed for you, they will stand behind the workmanship and assist as needed. I am talking from experience. I suggest you call Roger Sorel. An email also works. Would suggest not use the forum to contact SAI. The staff does check the site and replies but issues are better resolved with direct contact. Good luck +1 . Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted October 4, 2011 Report Share Posted October 4, 2011 Back in April 2009 I was told that there is NO warranty on Whipple 550 installs. So if I blew the engine up I would be SOL. Just curious to when Shelby American started offering warranty on Whipple 550 installs? FRPP offered no warranty on a 550 no matter who installed it, your dealer was either stroking you or being cooler than the warranty. My undrrstanding was 550 kit made drivetrain warranty void. But honestly who cares, these things are so much fun! edit: so the 12 months is on the part I believe? May pull out wgipple book to read. Link to comment Share on other sites More sharing options...
NordicShelby Posted October 4, 2011 Report Share Posted October 4, 2011 FRPP offered no warranty on a 550 no matter who installed it, your dealer was either stroking you or being cooler than the warranty. My undrrstanding was 550 kit made drivetrain warranty void. But honestly who cares, these things are so much fun! :beerchug: Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted October 4, 2011 Report Share Posted October 4, 2011 Back in April 2009 I was told that there is NO warranty on Whipple 550 installs. So if I blew the engine up I would be SOL. Just curious to when Shelby American started offering warranty on Whipple 550 installs? FRPP offered no warranty on a 550 no matter who installed it, your dealer was either stroking you or being cooler than the warranty. My undrrstanding was 550 kit made drivetrain warranty void. But honestly who cares, these things are so much fun! Link to comment Share on other sites More sharing options...
NordicShelby Posted October 4, 2011 Report Share Posted October 4, 2011 Your Ford Racing Whipple Supercharger carries a 12/12 warranty from Ford Racing. Shelby also honors that warranty on Ford racing parts and 12 months from in service date on all installations and defective parts and workmanship. Roger Thanks for clearing up this confusion Roger. Link to comment Share on other sites More sharing options...
SWEDEMAN Posted October 5, 2011 Report Share Posted October 5, 2011 Really! If don't remember recieving your call on this issue. We we do our best to assist everyone with their issues. Shelby related or not and have a dedicated customer service and technical rep ready to assist. Your Ford Racing Whipple Supercharger carries a 12/12 warranty from Ford Racing. Shelby also honors that warranty on Ford racing parts and 12 months from in service date on all installations and defective parts and workmanship. Looking at your in service date we would have also contacted Michael at Whipple for possible causes and resolution. Rogers@shelbyamerican.com or 702-942-7325 ext. 145. I am available after 7 AM. Roger I have blasted Roger and SA in the past for issues related and unrelated to my installation but I will say this...Roger tried extremely frign hard to solve the one last remaining issue I had after everything that they did mechanically, the dyno issue. This was never resolved because they either forgot to do a final one after the initial 516 RWHP dyno or it got lost in the shuffle. But all in all the GT/SC work is awesome, that being said I have no beef with Roger or his integrity in the end. Link to comment Share on other sites More sharing options...
jwestercamp Posted October 5, 2011 Report Share Posted October 5, 2011 Talked to Michael at Whipple, Friday. I have to send the supercharger to Whipple in, Califorina. Never had any luck talking to Roger. Always someone else's problem. Roger is the man he has always helped me with anything that I have needed. I find this hard to believe. SA and SPP have always come through for me. Good luck to ya Link to comment Share on other sites More sharing options...
AstroDan Posted October 6, 2011 Report Share Posted October 6, 2011 Roger is the man he has always helped me with anything that I have needed. I find this hard to believe. SA and SPP have always come through for me. Good luck to ya Me too. +1 It sounds like the oil is making it's way through the intake, so there is no residue. Mines been on and driven about 8,000 miles with no oil loss. It is a hoot. Link to comment Share on other sites More sharing options...
NordicShelby Posted October 6, 2011 Report Share Posted October 6, 2011 Mine has been on for over 15,000 miles without any oil loss whatsoever and I would guess that 5,000 of those miles have been on the track going as fast I as I can go until some slow sucker gets in front of me and won't let me pass. I had the Whipple installed at around 5,000 miles and now I have a little over 20,000 on the SGT. Link to comment Share on other sites More sharing options...
Jer Posted October 7, 2011 Report Share Posted October 7, 2011 Mine has been on for over 15,000 miles without any oil loss whatsoever and I would guess that 5,000 of those miles have been on the track going as fast I as I can go until some slow sucker gets in front of me and won't let me pass. I had the Whipple installed at around 5,000 miles and now I have a little over 20,000 on the SGT. Sorry to be boring but: Just call Roger. Jer Link to comment Share on other sites More sharing options...
NordicShelby Posted October 7, 2011 Report Share Posted October 7, 2011 Sorry to be boring but: Just call Roger. Jer What do I need to call Roger for? My Whipple doesn't leak Link to comment Share on other sites More sharing options...
Jer Posted October 7, 2011 Report Share Posted October 7, 2011 What do I need to call Roger for? My Whipple doesn't leak Sorry, that was meant for the original poster, I quoted the wrong post. Jer Link to comment Share on other sites More sharing options...
zachman Posted October 18, 2011 Author Report Share Posted October 18, 2011 Mike from Whipple called today and said the inner seal was blown out. Supercharger needed a standard rebuild. Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted October 18, 2011 Report Share Posted October 18, 2011 So good thing ypu noticed oil down. Good thing. Any reason for failure? Thanks for posting I have been wondering what the answer was... Link to comment Share on other sites More sharing options...
