89Saleen215 Posted September 15, 2011 Report Share Posted September 15, 2011 I obtained a set of twist-locks and plates, however, trying to find information on how the plates are mounted to the radiator support is next to impossible. The one Shelby annual shows a jig that Shelby used when putting the the plates on. From what I can tell it allowed them to drill out the hood bump-stops and it's rise as well as drill for the inner mounting hole. So my assumptions are: 1) The outer mounting hole uses the headlight bolt/mount. So did they use a longer bolt because of the plate or did they just reuse the factory headlight bolt? 2) The bump-stop "mounds" were drilled out making about a 1 1/2" hole for the twist-lock pin. If I'm correct about the above assumptions then the only issue unsolved is how are the inner bolts installed? What bolts are used and what are they tightened to? Does anyone know this information or would someone with a KR want to take 2 bolts out and take some pics for me? Pretty please Thanks for any help with this. Link to comment Share on other sites More sharing options...
FiaCobra Posted September 20, 2011 Report Share Posted September 20, 2011 Next time I have the hood open, I'll take a look. Link to comment Share on other sites More sharing options...
89Saleen215 Posted September 20, 2011 Author Report Share Posted September 20, 2011 Thank you so much. Just note that the radiator support is "tubular" so unless it goes "all the way thru" you might not be able to see the bottom of the bolt. Link to comment Share on other sites More sharing options...
txcobra Posted September 23, 2011 Report Share Posted September 23, 2011 Well, it looks like we'd have to pull the bracket and maybe the headlights to really see what's doing...The good news is the passenger side is the headlight bracket and the Hood Prop bracket, so that's clean. The Driver side is more complicated. The only problem with pulling them out, is they are very adjustable and is difficult to get them to line back up. Passenger Side: Driver side: Link to comment Share on other sites More sharing options...
89Saleen215 Posted September 24, 2011 Author Report Share Posted September 24, 2011 txcobra - Thanks for those pics. It does leave an interesting question - the pics supplied by txcobra show different bolts being used than all the other KR's I've seen. All the one's I've seen so far have the same dull aluminum looking bolts that are used all over the place under the hood. Why is this KR different or are all the one's I've seen to date different? Seems there was a change somewhere... Does anyone feel adventurous and want to take off the drivers side and take some pics? Link to comment Share on other sites More sharing options...
txcobra Posted September 24, 2011 Report Share Posted September 24, 2011 Interesting. I bought my car brand new and never made any modifications so I'm not sure how mine are different. Can the rest of you guys check yours? Link to comment Share on other sites More sharing options...
eagledriver Posted September 24, 2011 Report Share Posted September 24, 2011 Interesting. I bought my car brand new and never made any modifications so I'm not sure how mine are different. Can the rest of you guys check yours? Yep, mine are more of a satin finish. Not at all like TXCobras photos. Perhaps a supplier change at some point? Link to comment Share on other sites More sharing options...
FiaCobra Posted September 25, 2011 Report Share Posted September 25, 2011 Ok, let me trek into the garage, undo the car cover, pop the hood, take pics, and upload them. Link to comment Share on other sites More sharing options...
FiaCobra Posted September 25, 2011 Report Share Posted September 25, 2011 Hope this helps. BTW, my KR is a 2009 model. Link to comment Share on other sites More sharing options...
89Saleen215 Posted September 25, 2011 Author Report Share Posted September 25, 2011 Before this gets too far - my bad! I just looked more carefully at all the pics I've taken over the years and it appears that depending on the angle of the pic that the bolt has a shoulder, but upon closer inspection it appears that they really are a different bolt with a washer. So that means that the headlight bolt must be a longer bolt to accommodate the washer and plate...now it's just figuring out how the inner bolts are installed. Link to comment Share on other sites More sharing options...
07-2937 Posted September 27, 2011 Report Share Posted September 27, 2011 the plates were installed using a rivnut and a jig Link to comment Share on other sites More sharing options...
