NMAv Posted September 7, 2011 Report Share Posted September 7, 2011 How long does it take to install the LCA relocation brackets. Trying ot judge if this is a evening jjob or a Saturday job. Looks pretty easy/straighforward. does anything else need to be done when this is complete? Someone mentioned something about an allignment???? Link to comment Share on other sites More sharing options...
SoFL05GT Posted September 7, 2011 Report Share Posted September 7, 2011 Deleted Link to comment Share on other sites More sharing options...
NMAv Posted September 8, 2011 Author Report Share Posted September 8, 2011 OK, that sounds like a Saturday project. I want to do the bump stops as well so I will but the rear in the air, remove the tires, do the bump stops during the week, then to the LCA relocation brackets on Saturday. Link to comment Share on other sites More sharing options...
IA Shelby Posted September 8, 2011 Report Share Posted September 8, 2011 which ones are going with? I was looking at BMR and Steeda. They recommend welding them in. Were you planning to do that or just bolt them on? I don't know enough to know if this is really required. Also what LCA's did you pick? Thanks Link to comment Share on other sites More sharing options...
NMAv Posted September 8, 2011 Author Report Share Posted September 8, 2011 I went with the J&M LCA and the BMR relocation brackets. I was planning on just bolting them in after discussing the matter with Van @ revanracing. Link to comment Share on other sites More sharing options...
0201212 Posted September 8, 2011 Report Share Posted September 8, 2011 If you plan on racing have sticky tires or have a good amount of power I would recommend having them welded in place. Link to comment Share on other sites More sharing options...
glroy Posted September 8, 2011 Report Share Posted September 8, 2011 If you plan on racing have sticky tires or have a good amount of power I would recommend having them welded in place. ++ better safe than a big surprise one day. Link to comment Share on other sites More sharing options...
IA Shelby Posted September 8, 2011 Report Share Posted September 8, 2011 Thanks guys - since I plan to add better tires and a TVS over the winter I think I am going to have them welded in. My only hesitation is that I hate squeaks and rattles. I know there is a strong possibility of this when adding suspension parts. If I bolted them in I can always remove and take them out worst case scenario. Welding complicates this a bit. I am thinking of BMR bracket with roush billet LCA with the rubber bushings compared to poly bushings. I am willing to trade off some traction for no NVH. Thoughts??? I am about to make a mistake? Link to comment Share on other sites More sharing options...
0201212 Posted September 9, 2011 Report Share Posted September 9, 2011 The brackets will not be the cause of a squeak so no problems there. I would suggest at least poly bushings as it is hard to get rubber to be stiff enough to keep things from moving around more then needed. If you have any type of exhaust work then you more then likely won't here mor nvh then now anyways. Hope that helps. I have all hiem joint connection points and I can deal with the extra noise. I just push on the loud pedal some more. Link to comment Share on other sites More sharing options...
frazierfreud Posted September 10, 2011 Report Share Posted September 10, 2011 I'm about to put on some bmr lca and bmr lca relocation brackets. I have good power and sticky tires. Is the idea behind welding the relocation brackets that it can come off with all the torque? U would think if the hardware is torqued down properly, it wouldn't be an issue. Link to comment Share on other sites More sharing options...
wingsnut Posted September 10, 2011 Report Share Posted September 10, 2011 I'm about to put on some bmr lca and bmr lca relocation brackets. I have good power and sticky tires. Is the idea behind welding the relocation brackets that it can come off with all the torque? U would think if the hardware is torqued down properly, it wouldn't be an issue. With good power and sticky tires I would recommend welding them in. If they are not welded in they have a tendency to bend which can cause issues with pinion angle and tires hitting wheel wells. Link to comment Share on other sites More sharing options...
