blacknblown11 Posted August 24, 2011 Report Share Posted August 24, 2011 I'd like to change the rear differential fluid. Will I need a new gasket? Quote Link to comment Share on other sites More sharing options...
shel-b001 Posted August 24, 2011 Report Share Posted August 24, 2011 I'd like to change the rear differential fluid. Will I need a new gasket? You don`t have to use a gasket but I put one on when I installed the Shelby girdle cover. Sealant will do as long as the cover has a good surface. Quote Link to comment Share on other sites More sharing options...
SteelTownStang Posted August 24, 2011 Report Share Posted August 24, 2011 I recommend a sealant or a gasket. Also... while you're at it, add a girdle (w/filler plug and drain) for ease of future maintenance... Quote Link to comment Share on other sites More sharing options...
6-Speed Posted August 25, 2011 Report Share Posted August 25, 2011 (edited) I use a Lube Locker gasket ... works great! http://www.bluecollarperformance.com/llr-f880.html http://www.svtperformance.com/forums/how-279/625983-how-i-installed-ford-racing-axle-girdle.html Edited August 25, 2011 by 6-Speed Quote Link to comment Share on other sites More sharing options...
dbackg Posted August 25, 2011 Report Share Posted August 25, 2011 I use a Lube Locker gasket ... works great! http://www.bluecolla...m/llr-f880.html http://www.svtperfor...xle-girdle.html +1 Quote Link to comment Share on other sites More sharing options...
