10SHELBY Posted August 22, 2011 Report Share Posted August 22, 2011 (edited) Ok, well I replaced my OEM wheels and tires with the Super Snake wheels from Shelby and Nitto Invos. I had a little problem with vibration and I had the wheels all checked and one was out of round. I had that wheel replaced and thought it would correct it. It did not correct the front end vibration. I had all four wheels rebalanced and it did not help. I had the two front done again and they are 0,0. The vibration is till there. The car has been lowered and the alignment checked and corrected after it was lowered. I am lost. I am running about 40 psi in the front tires. The vibration comes in about 55 - 65 mph. I would appreciate any help that anyone could offer. I don't drive it much but in 2 weeks I need to put about 300 miles on it and I hate driving it like this. Rudy Edited August 22, 2011 by 10SHELBY Quote Link to comment Share on other sites More sharing options...
BAD SNAKE Posted August 22, 2011 Report Share Posted August 22, 2011 Did you remove the "keepers" on your wheel lugs? They are small pieces of black metal that attach tour wheel lugs to keep the rotor's in place when they build the car. Quote Link to comment Share on other sites More sharing options...
10SHELBY Posted August 23, 2011 Author Report Share Posted August 23, 2011 Did you remove the "keepers" on your wheel lugs? They are small pieces of black metal that attach tour wheel lugs to keep the rotor's in place when they build the car. No I did not have a problem with my OEM wheels and vibration. Do you think that will help? Rudy Quote Link to comment Share on other sites More sharing options...
BAD SNAKE Posted August 23, 2011 Report Share Posted August 23, 2011 No I did not have a problem with my OEM wheels and vibration. Do you think that will help? Rudy You might check it out, it wouldn't hurt to remove them. If the wheel fits tight to the rotor I would think they would get in the way. Quote Link to comment Share on other sites More sharing options...
Cobras55 Posted August 24, 2011 Report Share Posted August 24, 2011 I don't know if this is your problem or not but you are def. Running to much air pressure, Try getting rid of at least 5-8 psi...may just solve your problem. Another thing keep in mind that the compound on these tires are very soft and they do flat spot overnight. Make sure you get them good and warmed up, 5-10 mins of driving. If none of that works try a Road Force Balance on a Hunter machine....GL.. Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted August 24, 2011 Report Share Posted August 24, 2011 (edited) I would appreciate any help that anyone could offer. I don't drive it much but in 2 weeks I need to put about 300 miles on it and I hate driving it like this. I think I've heard that the 20" Alcoa "Super Snake" wheels DO fit flat on your rotor face so try removing the factory keepers, just for shits and giggles. And someone else also warned you about your pressure. That's WAY too high. I don't think it's the cause of your vibration but it's way too high. You'll wear the centers out of those tires in short time at that pressure. By some slim chance, did whoever put your car on a rack ding/dent your driveshaft with the rack??? Do you feel the vibration in the stearing wheel or just in the front end of the car? Only when braking or always (at the same speed)??? EDIT: Move your wheels from front to back (per side) and see if the problem moves with the wheels. It won't hurt the tires/wheels if you keep them on their respective sides and they DO fit when you put the rears on the front. If the problem moves with the wheels, try moving one side back to OE and see if the problem moves with a particular side. If it doesn't move with the wheels, start looking for something loose in the front stearing system then the front suspension system. Now, not to hi-jack your thread but I notice you have a 2010+ model car with a aftermarket gas filler cap on it. Any chance you can post a close-up pic of it? And where did you get it from? Is is still retain the capless filler feature? I've never seen a AM cap on a 2010+ car and in fact, did not know they were available. TIA, Phill Edited August 24, 2011 by 2010KonaBlueGT Quote Link to comment Share on other sites More sharing options...
enormous Posted August 24, 2011 Report Share Posted August 24, 2011 I got rid of a front end vibration with a road Force balance, As mentioned earlier take the keepers off the studs and try 32-33 lbs. Quote Link to comment Share on other sites More sharing options...
SteelTownStang Posted August 24, 2011 Report Share Posted August 24, 2011 ... as mentioned. Remove the stud clips that secured the rotors during the build. They are no longer needed. Your wheels are not sitting flat, hence, the vibration. Very easy task- just use wire snippers, or equivalent… and cut all 4 of them off... including the rear. Quote Link to comment Share on other sites More sharing options...
10SHELBY Posted August 25, 2011 Author Report Share Posted August 25, 2011 I think I've heard that the 20" Alcoa "Super Snake" wheels DO fit flat on your rotor face so try removing the factory keepers, just for shits and giggles. And someone else also warned you about your pressure. That's WAY too high. I don't think it's the cause of your vibration but it's way too high. You'll wear the centers out of those tires in short time at that pressure. By some slim chance, did whoever put your car on a rack ding/dent your driveshaft with the rack??? Do you feel the vibration in the stearing wheel or just in the front end of the car? Only when braking or always (at the same speed)??? EDIT: Move your wheels from front to back (per side) and see if the problem moves with the wheels. It won't hurt the tires/wheels if you keep them on their respective sides and they DO fit when you put the rears on the front. If the problem moves with the wheels, try moving one side back to OE and see if the problem moves with a particular side. If it doesn't move with the wheels, start looking for something loose in the front stearing system then the front suspension system. Now, not to hi-jack your thread but I notice you have a 2010+ model car with a aftermarket gas filler cap on it. Any chance you can post a close-up pic of it? And where did you get it from? Is is still retain the capless filler feature? I've never seen a AM cap on a 2010+ car and in fact, did not know they were available. TIA, Phill Thanks to all for the advise. I will remove the keepers and lower the air some. The vibration is in the wheel and at about the same speed and there has been no drive shaft problem. My wheels are stagered so I can not swap them front to back. The gas door is a Silver Horse Racing item and you will retain everything. It is a pain to install but worth it. I will get a closer photo. SHR Fuel Door Rudy Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted August 25, 2011 Report Share Posted August 25, 2011 My wheels are stagered so I can not swap them front to back. I'm pretty sure you can. Robert M. has a Super Snake and he's running a set of 10" SS wheels/tires up front, and he has the Baer brakes too. I wouldn't run like that for long becase you're putting narrower tires on the back and you're already traction limited, but as far as pure FIT...I'm pretty sure you can (almost positive). Phill Quote Link to comment Share on other sites More sharing options...
10SHELBY Posted August 27, 2011 Author Report Share Posted August 27, 2011 Did you remove the "keepers" on your wheel lugs? They are small pieces of black metal that attach tour wheel lugs to keep the rotor's in place when they build the car. WOW, I really questioned if that could be the answer however BINGO. I did it yesterday before Irene stopped by and took it out for a test drive. I was blown away. It changed things 100%. Thanks to BAD SNAKE and all that had suggestions. The keepers was the answer. BTW Irene has arrived here in Tidewater VA and she is kickin'. Thanks again, Rudy Quote Link to comment Share on other sites More sharing options...
BAD SNAKE Posted August 28, 2011 Report Share Posted August 28, 2011 WOW, I really questioned if that could be the answer however BINGO. I did it yesterday before Irene stopped by and took it out for a test drive. I was blown away. It changed things 100%. Thanks to BAD SNAKE and all that had suggestions. The keepers was the answer. BTW Irene has arrived here in Tidewater VA and she is kickin'. Thanks again, Rudy Sweet! I'm glad it worked out! Stay safe. Quote Link to comment Share on other sites More sharing options...
daveh70 Posted August 30, 2011 Report Share Posted August 30, 2011 I had a vibration happening when I did a left to right rotation on the CS40 20 inch wheels I got for the '08. When I rotated them back the vibration stopped. Try rotating your wheels (left side to right side) and see if that stops it. Quote Link to comment Share on other sites More sharing options...
