wanted2b Posted August 7, 2011 Report Share Posted August 7, 2011 Well, today was my first time for hitting the go pedal hard. It is amazing what that car will do, but, the wheel hop is awful. This has to be fixed. Does anyone know what to do? I sure want to correct this problem before I do any mods. Thanks in advance for any and all information. Dark Side will thank you I'm sure. Link to comment Share on other sites More sharing options...
Bish Posted August 7, 2011 Report Share Posted August 7, 2011 The Roush Anti Wheel Hop kit is a quality option, IMHO. Well, today was my first time for hitting the go pedal hard. It is amazing what that car will do, but, the wheel hop is awful. This has to be fixed. Does anyone know what to do? I sure want to correct this problem before I do any mods. Thanks in advance for any and all information. Dark Side will thank you I'm sure. Link to comment Share on other sites More sharing options...
DOGEMAN223 Posted August 7, 2011 Report Share Posted August 7, 2011 I used steeda adjustable upper control control arm set the pinion angle at minus 1degree and replace lower control arm but these are fixed. Sounds confusing but it's not. Elliot Link to comment Share on other sites More sharing options...
IA Shelby Posted August 7, 2011 Report Share Posted August 7, 2011 I used steeda adjustable upper control control arm set the pinion angle at minus 1degree and replace lower control arm but these are fixed. Sounds confusing but it's not. Elliot I am going back and forth on the roush vs steeda set up. How much increase in NVH did you get with the lower control arms with steeda? Did you weld in the lower relo brackets? Did you get the aluminum drive shaft. Steeda rep was telling me I needed the drive shaft to avoid any clunking noise. Link to comment Share on other sites More sharing options...
BlakSnake Posted August 7, 2011 Report Share Posted August 7, 2011 Do the Roush. It just works. Problem solved. Link to comment Share on other sites More sharing options...
Cobras55 Posted August 7, 2011 Report Share Posted August 7, 2011 I just have lower control arms and I have no wheel hop,,,, the upper control arm translates to much noise to the cabin and isn't needed, at least for me that is. Link to comment Share on other sites More sharing options...
jerseygator Posted August 7, 2011 Report Share Posted August 7, 2011 Link to comment Share on other sites More sharing options...
SteelTownStang Posted August 7, 2011 Report Share Posted August 7, 2011 Start with the LCAs... if it doesn’t work, then add UCAs. You can also try swapping out the OEM bushings. Note that any modification may have undesirable effects, i.e., harsher ride, noise, etc. I've read good reviews on the Roush set-up. Personally, lowering springs fixed it for me... If you conduct some research, you'll discover that each car is unique with regards to wheel hop, and its remedy is not entirely universal. Link to comment Share on other sites More sharing options...
wanted2b Posted August 7, 2011 Author Report Share Posted August 7, 2011 First step is the Roush anti wheel hop kit. Then LCAs after that. Thanks for the information and advice Link to comment Share on other sites More sharing options...
BigDan Posted August 7, 2011 Report Share Posted August 7, 2011 Were you on level pavement and did you try it on different surfaces, what speed and what gear? Link to comment Share on other sites More sharing options...
DOGEMAN223 Posted August 8, 2011 Report Share Posted August 8, 2011 I am going back and forth on the roush vs steeda set up. How much increase in NVH did you get with the lower control arms with steeda? Did you weld in the lower relo brackets? Did you get the aluminum drive shaft. Steeda rep was telling me I needed the drive shaft to avoid any clunking noise. What is NVH? Lower control arms I got from ebay, machined aluminium style control arms they were 200.00 I tried with lower first but wheel hop did not go away. Then I tried with upper adjustable control arm from Steeda and this was it, but you need to make sure you don't set the pinion angle too low I tried from -1 to -4. Lower the pinon angle more the stress you put on the pinion but less llikely you will get wheel hop. I tried all settings and I came to conclusion -1 is the best setting. I am telling you from 3mo's trying diffrent settings. I had kennebell 2.8l set up with 15psi boost. I am not sure about the drive shaft because Kennebell said I had to buy 1 piece drive drive shaft so I purchased 1 piece steel shaft. You will find out lower the setting you set the pinon angle greater the noise is. Safeist setting is -1. Elliot Link to comment Share on other sites More sharing options...
BigDan Posted August 8, 2011 Report Share Posted August 8, 2011 What is NVH? NVH: Wikipedia Link to comment Share on other sites More sharing options...
Wingrider Posted August 9, 2011 Report Share Posted August 9, 2011 Dan- I didn't see you at Infineon this past weekend for Mini Nats.. Link to comment Share on other sites More sharing options...
NMAv Posted August 9, 2011 Report Share Posted August 9, 2011 NVH: Wikipedia That's right - Norwegian School of Veterinary Science Link to comment Share on other sites More sharing options...
