NMAv Posted June 21, 2011 Report Share Posted June 21, 2011 Has anyone with a 2010 - 2012 GT 500 tried to put in an H/E unit and the Boss 302 brake ducts. I'm wondering if there will be a clearance issue. Link to comment Share on other sites More sharing options...
NMAv Posted July 6, 2011 Author Report Share Posted July 6, 2011 Anyone ... Link to comment Share on other sites More sharing options...
NMAv Posted July 17, 2011 Author Report Share Posted July 17, 2011 For those that are interested the answer is yes, they will fit. Link to comment Share on other sites More sharing options...
Wingrider Posted July 20, 2011 Report Share Posted July 20, 2011 Has anyone with a 2010 - 2012 GT 500 tried to put in an H/E unit and the Boss 302 brake ducts. I'm wondering if there will be a clearance issue. No problem. Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted July 20, 2011 Report Share Posted July 20, 2011 What is the H/E? Heat exchanger for something? Link to comment Share on other sites More sharing options...
Wingrider Posted July 21, 2011 Report Share Posted July 21, 2011 Heated Exhaust. Stock on 2010+ Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted July 23, 2011 Report Share Posted July 23, 2011 For those that are interested the answer is yes, they will fit. Are the backing plates (dust shields) flat or are they recessed like the earlier FRPP brake duct shields? I have the Shelby/Baer 6S Extreame brakes and the earlier FRPP backing plates won't work because they sitck out from the mounts and rub on the rotors. If the new version has flat shields, they should work on the Baer rotors. I'm willing to remove my fog lamps (don't really use 'em anyway) so I can use the recess for the new Boss 3" ducts but I don't want to spend the money AGAIN only to find out they won't work with the Baers. Any idea? TIA, Phill Pollard Link to comment Share on other sites More sharing options...
NMAv Posted July 23, 2011 Author Report Share Posted July 23, 2011 I've still got the front tires off, will take a couple pictures for you later today. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted July 23, 2011 Report Share Posted July 23, 2011 I've still got the front tires off, will take a couple pictures for you later today. Cool, thanks. Do you still have stock rotors or aftermarket rotors? I'm more interested in how "flat" the backing plates mount to the spindle than anything else. The early versions are pressed so the mounting tabs are deeper than the rest of the plate, which sticks the plate out a little towards the rotor. I could modify them but I'd rather sell a pristine set to someone that needs them then hack 'em and be stuck with a $125 paper weight. TIA, Phill Link to comment Share on other sites More sharing options...
NMAv Posted July 23, 2011 Author Report Share Posted July 23, 2011 The mounting tab is definitely 1/2 inch to 5/8ths deeper. Link to comment Share on other sites More sharing options...
NMAv Posted July 23, 2011 Author Report Share Posted July 23, 2011 Phill, The pictures don't capture the depth of the mounting tab (wish I had taken pictures before I put them in). Send me a PM with your e-mail an dI'll e-mail them to you. Can't seem to get them to post here. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted July 24, 2011 Report Share Posted July 24, 2011 Phill, Send me a PM with your e-mail an dI'll e-mail them to you. PM sent. Phill Link to comment Share on other sites More sharing options...
