erikbuckland Posted June 14, 2011 Report Share Posted June 14, 2011 when I turn hard and fast the back of the car rattles. Sounds like something rollin around in the trunk, but nothing is there. For those that have experienced needing their muffler brackets replaced, is this the tall tale sign that my brackets are broken? If they do need replacing, it is an easy job to do yourself? If I am under the car replacing brackets, does anyone have any suggestions for what I should use for an undercoating? Link to comment Share on other sites More sharing options...
JeffJ Posted June 14, 2011 Report Share Posted June 14, 2011 Check your rear sway bar mounts also for any loseness. Sounds like possible location for your rattle. They do also need a bit of grease between the poly bushing and the bar. Link to comment Share on other sites More sharing options...
