autoxstang Posted May 31, 2011 Report Share Posted May 31, 2011 Hey guys I'm getting ready to install my FRPP springs and MM camber/caster plates and I noticed in the instructions that they recommend replacing the "strut-to-spindle mounting hardware" stating that "Ford considers this hardware as one time use". I was just curious as to how many people changed the bolts and nuts on the strut? If not is the hardware actually reuseable? Thanks in advance for all of your replies. Link to comment Share on other sites More sharing options...
89Saleen215 Posted May 31, 2011 Report Share Posted May 31, 2011 MM has the best price for these (MMF-3) - unless you can find it cheaper at a dealer. They have a finer thread and a higher torque spec. I've used these when doing this job on both my cars. Link to comment Share on other sites More sharing options...
wingsnut Posted June 5, 2011 Report Share Posted June 5, 2011 MM has the best price for these (MMF-3) - unless you can find it cheaper at a dealer. They have a finer thread and a higher torque spec. I've used these when doing this job on both my cars. Anybody know what other hardware is one time use when installing the FR3 handling pack? Found this list of "one time" use hardware on another site, don't know if it is accurate as I haven't checked the part numbers. Lower Control Arms: Front Bolt: W711504-S439 Qty: 2 Front Nut: W710089-S440 Qty: 2 Rear Bolt: W704888-S900 Qty: 2 Rear Nut: W704991-S900 Qty: 2 Rear Sway Bar: Axle Bolt: W711368-S439 Qty: 4 Axle Nut: W520213-S440 Qty: 4 Stabilizr Bolt: W708737-S439 Qty: 2 Stabilizer Nut: W711029-S900 Qty: 2 Panhard Rod: Bolts: W704886-S439 (superseeds to W711504-S439) Qty: 2 Axle Nut: W710689-S900 Qty: 1 Body Nut: W710022-S900 Panhard Rod Support: Driver's Side Body Bolt: W7113310S439 Qty: 2 Pass. Side Body Bolt: W710693-S439 Qty: 1 Pass. Side Body Nut: W520214-S440 Qty:1 Upper Control Arm: Axle Bolt: Qty: 1 Axle Nut: Qty: 1 Body Bolt: Qty: 1 Body Nut: Qty: 1 Upper Control Arm Mount: Body Bolt: Qty: Rear Shocks: Axle Bolt: W709878-S439 Qty: 2 Axle Nut: W710436-S900 Qty: 2 Upper Nut: 4R3Z-18197-AA Qty: 2 Front Struts: Strut-to-Wheel bolt: W709870-S439 Qty: 4 Strut-to-Wheel nut: W711091-S900 Qty: 4 Linkage Nut: N8071440-S440 Qty: 4 Upper Nut: W520215-S440 Qty: 2 Strut Cap Nuts: W520112-S440 Qty: 8 Link to comment Share on other sites More sharing options...
SteelTownStang Posted June 5, 2011 Report Share Posted June 5, 2011 Just installed the FRPP springs only. No problems w/alignment. I do, however, have an adjustable panhard bar that had to be re-adjusted to align the rear axle. No camber/caster plates and reused the shock bolts with no issues. Link to comment Share on other sites More sharing options...
dbackg Posted June 5, 2011 Report Share Posted June 5, 2011 Anybody know what other hardware is one time use when installing the FR3 handling pack? Found this list of "one time" use hardware on another site, don't know if it is accurate as I haven't checked the part numbers. Lower Control Arms: Front Bolt: W711504-S439 Qty: 2 Front Nut: W710089-S440 Qty: 2 Rear Bolt: W704888-S900 Qty: 2 Rear Nut: W704991-S900 Qty: 2 Rear Sway Bar: Axle Bolt: W711368-S439 Qty: 4 Axle Nut: W520213-S440 Qty: 4 Stabilizr Bolt: W708737-S439 Qty: 2 Stabilizer Nut: W711029-S900 Qty: 2 Panhard Rod: Bolts: W704886-S439 (superseeds to W711504-S439) Qty: 2 Axle Nut: W710689-S900 Qty: 1 Body Nut: W710022-S900 Panhard Rod Support: Driver's Side Body Bolt: W7113310S439 Qty: 2 Pass. Side Body Bolt: W710693-S439 Qty: 1 Pass. Side Body Nut: W520214-S440 Qty:1 Upper Control Arm: Axle Bolt: Qty: 1 Axle Nut: Qty: 1 Body Bolt: Qty: 1 Body Nut: Qty: 1 Upper Control Arm Mount: Body Bolt: Qty: Rear Shocks: Axle Bolt: W709878-S439 Qty: 2 Axle Nut: W710436-S900 Qty: 2 Upper Nut: 4R3Z-18197-AA Qty: 2 Front Struts: Strut-to-Wheel bolt: W709870-S439 Qty: 4 Strut-to-Wheel nut: W711091-S900 Qty: 4 Linkage Nut: N8071440-S440 Qty: 4 Upper Nut: W520215-S440 Qty: 2 Strut Cap Nuts: W520112-S440 Qty: 8 good find. thanks for sharing. I think the rear sway bar has a plate with 2 holes for the back side of the bushing Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted June 12, 2011 Report Share Posted June 12, 2011 Hey guys I'm getting ready to install my FRPP springs and MM camber/caster plates and I noticed in the instructions that they recommend replacing the "strut-to-spindle mounting hardware" stating that "Ford considers this hardware as one time use". I was just curious as to how many people changed the bolts and nuts on the strut? If not is the hardware actually reuseable? Thanks in advance for all of your replies. I installed the FR3 kit on my '10 GT500 and reused ALL of the factory fasteners without any problem what so ever. I did put Caster/Camber plates on the struts and they come with new locknuts so I did use those but on the spindle, I reused the factory bolts/nuts. They have what looks like blue lock-tite on them from the factory so if anything, put some more on to replace the factory goo. Phill Link to comment Share on other sites More sharing options...
TheKurgan Posted October 3, 2014 Report Share Posted October 3, 2014 Anybody know what other hardware is one time use when installing the FR3 handling pack? Found this list of "one time" use hardware on another site, don't know if it is accurate as I haven't checked the part numbers. Lower Control Arms: Front Bolt: W711504-S439 Qty: 2 Front Nut: W710089-S440 Qty: 2 Rear Bolt: W704888-S900 Qty: 2 Rear Nut: W704991-S900 Qty: 2 Rear Sway Bar: Axle Bolt: W711368-S439 Qty: 4 Axle Nut: W520213-S440 Qty: 4 Stabilizr Bolt: W708737-S439 Qty: 2 Stabilizer Nut: W711029-S900 Qty: 2 Panhard Rod: Bolts: W704886-S439 (superseeds to W711504-S439) Qty: 2 Axle Nut: W710689-S900 Qty: 1 Body Nut: W710022-S900 Panhard Rod Support: Driver's Side Body Bolt: W7113310S439 Qty: 2 Pass. Side Body Bolt: W710693-S439 Qty: 1 Pass. Side Body Nut: W520214-S440 Qty:1 Upper Control Arm: Axle Bolt: Qty: 1 Axle Nut: Qty: 1 Body Bolt: Qty: 1 Body Nut: Qty: 1 Upper Control Arm Mount: Body Bolt: Qty: Rear Shocks: Axle Bolt: W709878-S439 Qty: 2 Axle Nut: W710436-S900 Qty: 2 Upper Nut: 4R3Z-18197-AA Qty: 2 Front Struts: Strut-to-Wheel bolt: W709870-S439 Qty: 4 Strut-to-Wheel nut: W711091-S900 Qty: 4 Linkage Nut: N8071440-S440 Qty: 4 Upper Nut: W520215-S440 Qty: 2 Strut Cap Nuts: W520112-S440 Qty: 8 I came across this thread via google while searching for the spindle to strut nut part number. This information above is no longer accurate due to Ford changing the part numbers. The service manual is wrong. So someone else doesn't make the same mistake I just did, I'll update it. Why Ford still make the old nuts is beyond me but I can confirm due to the bolt not fitting in the nut Here are the upgraded part numbersue W714652-S439 (bolts) & W714653-S900 (nuts) The old part numbers: W709870-S439 (bolts) & W711091-S900 (nuts) Link to comment Share on other sites More sharing options...
